Page 13 of 20 FirstFirst ... 34567891011121314151617181920 LastLast
Results 121 to 130 of 196
Thread: Tutorial - Steering Wheel Controls
  1. #121
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    Directory: A folder that is an entity in a file system which contains a group of files and/or other directories.
    File: A set of related information that a computer can access by a unique name
    When the configurator saves the configuration, it save an XML file, along with a content directory that contains other directories and files such as images and fonts. Copy the XML file and not the content directory, you didnt complete the copy, things wont work.
    "MDX Program File" is Fusion Control Centre UberMDX.exe
    You can save over that file if you really want to, but then you dont have a program any more and nothing will work.
    MDX's directory is the entity that contains Fusion Control Centre UberMDX.exe directly (not within another directory). You could have it saved in the default location "C:\Program Files\Fusion Control Centre Uber MDX Edition\MDX" or you can save it to F:\Fluffy Bunny\ it doesnt matter as long as it is where you installed the program to.
    If your program installed to F:\Fluffy Bunny\ and you save your configuration file to Z:\Doom, then how will the program in Fluffy Bunny know to look in one of a billion directories on your computer, the internet, your network, your flash drives, everything to find that one specific file on Z:\Doom???. Common sense dictates it will not search the universe for 1 file, it will instead read what it can from the Fluffy Bunny directory.
    So save whereever you like, but to get it to work, you better save it where the program is installed to.
    MDX FOLDER ONLY ALLOWS ONE CONFIGUATOR FILE , so how am I going to get he brain to see the values? Since I can change the current file in mdx folder?
  2. #122
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by customaudioman View Post
    Do what I said. Step by step.
  3. #123
    Oct 2005
    east coast
    Quote Originally Posted by greenman100 View Post
    okay I did that what do I do next?
  4. #124
    Mar 2008
    did you get any "a"'s in the notepad as he said it would?
  5. #125
    Mar 2008
    aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    Opps sorry, did not close MDX lol.. Ran your test and i got a's but only when i made the note pad (and this text box) the focus...
  6. #126
    Mar 2008
    I also created my own and did a DeBug on in and it was working with my virtual brain...
  7. #127
    Mar 2005
    So run this, apply a voltage to analog input 0, and open a notepad window - it'll start filling up with "a"s.
    did this happen for you?
  8. #128
    Oct 2005
    east coast
    no, I SAVED the new file like you said, not as note pad, xl .
  9. #129
    Mar 2008
    how can i delay the time between presses? and if possible can you explain a little bit more on how i can get this done
    if voltage > threshold, then increment a variable.
    If (voltage < threshold && variable > 0), then varaible = 0 and send key B.
    If (voltage > threshold && variable == 0), then send key A.
    if voltage < threashold, then variable = 0
    2k1 posted that for me but i am confused on how to implement it.
    THanks and sorry to bother soo much..
  10. #130
    Oct 2005
    east coast
    why does all the digital out on when I open the program?
  1. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 05-21-2009, 11:22 PM
  2. Toyota Steering Wheel Control Question
    By 205GTi in forum Input Devices
    Last Post: 02-19-2009, 08:38 AM
  3. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
