Page 19 of 20 FirstFirst ... 91011121314151617181920 LastLast
Results 181 to 190 of 197
Thread: Tutorial - Steering Wheel Controls
  1. #181
    Mar 2008
    lol i always reply to messages without completely reading. Its kool, no need to say sorry. your a busy guy and trust me i appreciate that your even taking the time to help me out.
    Here is the IF logic you asked for:
    <if fire_on="logic" minimum_delta_vote_time="5000" id="Mode Button">
    <boolean_operation type="between ii">
    <parameter1>
    <number>4.6</number>
    </parameter1>
    <parameter2>
    <analogue id="Steering Wheel Control" time="0"></analogue>
    </parameter2>
    <parameter3>
    <number>4.8</number>
    </parameter3>
    </boolean_operation>
    <then>
    <do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="M" vote_priority="Medium"></do>
    </then>
    </if>
    Also, could you make a simple calc for me using the 5v value? call me dumb but its a little confusion. Thank you once again
  2. #182
    Mar 2008
  3. #183
    Mar 2006
    Colorado, but Canadian!
    Did you get that update that went out a few days ago?
    1.9in x 2.9in -- 47mm x 73mm
  4. #184
    Mar 2008
    Yes sir...
  5. #185
    Mar 2006
    found the problem, ill post when I send out an update
  6. #186
    Mar 2006
    Update is on the server. Try now.
  7. #187
    Mar 2006
    As for the R value, use a 1K. That will give you 4.54v out at idle.
  8. #188
    Mar 2008
    Awesome, i will try as soon as i get the chance.
    calculated for 1.5 k and it was good. but i will redo calcs for 1k i think that will get me closer to the mark.
    Thanks alot bro.
  9. #189
    Mar 2006
    Quote Originally Posted by Urbanmindz View Post
    Thanks alot bro.
    1.5k will be fine. It is just the range of values you get increases with the smaller resistor, but also the current it draws goes up. So a 1ohm resistor will give you very close to 5v at 10kohms, but you will blow up the FB because that is 5v/1ohm = 5A. So 5amp draw. 5/1000 = 5mA which is perfectly safe to pull from the Brain. 5/1500 = 3.3mA, so it is fine too, but your maximum value when idle will be 4.35v.
  10. #190
    Mar 2008
    lol Another Question,,,,
    How can i get the vote delay to reset once the voltage is released? Once i release the button the vote delay is still active until it expires. Is there any way that the vote delay can expire immediately after the voltage is released, this way if a person wants to repress the buttons at a faster rate it will send the key stroke each time the button is pressed even if still within the vote delay time?
    Thank you,
  1. Toyota Steering Wheel Control Question
    By 205GTi in forum Input Devices
    Last Post: 05-21-2014, 09:57 PM
  2. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 11-16-2012, 01:19 PM
  3. Replies: 2
    Last Post: 05-23-2006, 11:56 AM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 04:27 AM
