Page 20 of 20 FirstFirst ... 1011121314151617181920
Results 191 to 197 of 197
Thread: Tutorial - Steering Wheel Controls
  1. #191
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Urbanmindz View Post
    lol Another Question,,,,
    How can i get the vote delay to reset once the voltage is released? Once i release the button the vote delay is still active until it expires. Is there any way that the vote delay can expire immediately after the voltage is released, this way if a person wants to repress the buttons at a faster rate it will send the key stroke each time the button is pressed even if still within the vote delay time?
    Thank you,
    No because that is the whole point of the minimum vote time to prevent that.
    So I am guessing the votes work?
    1.9in x 2.9in -- 47mm x 73mm
  2. #192
    Mar 2008
    2K1, i finally got everything set up in my car and for it working great.
    Thank you for all your help and effort in helping me out.
    Im sure you know this already, but I was having a problem where MDX would not detect the FB. A simple unplug of the USB and replug worked, but if i close MDX and Reopen, it would not detect again.
    This is not affecting me now because i got it working and dont need to close MDX, but it made it a pain when troubleshooting.
    Anyways once again, Thank you. Cant wait to get my FB v4 to play around with.
  3. #193
    Mar 2006
    Was the computer it didnt work on a non-Intel based machine?
    Glad everything is peachy.
  4. #194
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Okay I have been studying the tutorial, and I believe that my steering wheel set up is not covered. I believe that I have a 2 wire type steering wheel system, but both wires are control, and ground is a third.
    Here is the picture from the manual: As you can see, both wires listed have resistance, and they are the same value as the other wire for the opposite event. In other words seek up & down are each 165 ohms, but up is on terminal wire 16 an seek down in is on terminal wire 20.
    I want to start just by wiring this all up, and then do the software side next.
    Any direction for this would be helpful. I know that since FB does not read resistance I will need to build a voltage divider and since I have 2 wires, I would assume that I would have to build 2.
    Thanks in advance.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  5. #195
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    I know have a 2005 Chrysler 300c which uses the canbus system. Can I use the fusion brain for steering wheel controls? or just buy the joycon ex steering wheel control pc interface?
  6. #196
    Variable Bitrate nemo1's Avatar
    Jun 2006
    the diagram for voltage division is missing in solutions c / d. can someone post a new one please. thanks
  7. #197
    Oct 2013
    How do I measure the resistance of a steering wheel button using a digital multimeter? I don't currently have the multifunction steering wheel installed yet, so can I measure the resistance of the buttons without the steering wheel being installed and hooked into the ignition/electronic? I'm an electrical newbie, so any detailed instructions on how to measure the resistance of a button is greatly appreciated.
    Thanks a million!
  1. Toyota Steering Wheel Control Question
    By 205GTi in forum Input Devices
    Last Post: 05-21-2014, 10:57 PM
  2. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 11-16-2012, 02:19 PM
  3. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
