Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Tutorial/Documentation Requests
  1. #21
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    DC 12v fan control
    I searched and searched and couldn't find anything but with the MOSFET board, how do you control fan speeds through PWM with a 12v computer fan? I can do it with a PIC but I'm not sure how to do it with the FB and MDX.
    Thanks!
    Love
  2. #22
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    From what I understand the Fusion Brain can supply up to 400mA per output channel. I fan I have here by my computer says its rated for 0.4A (400mA). In my inexperience it would seem that my no-frills fan would likely trip the fuse/breaker with any little bit of variance (fan or Fusion Brain or power to the Brain). :/ I would think the MOSFET board would be the way to go...
  3. #23
    Nov 2008
    Look behind you.
    Ah, I checked my Cooler Master 120mm fan and it uses 0.16A (160mA), which is obviously under 400mA
    I'd say it depends on the fan.
  4. #24
    Jul 2008
    Mechanicsburg, PA
    Right, I have run fans from the FB before but I'd like to control the speed simply through an analogue voltage output (PWM). With the MOSFET board, how do you 'program' it in MDX to do it is my question.
    Love
  5. #25
    Mar 2006
    Colorado, but Canadian!
    Hardware wise, you can just hook it up directly. Power it off of the pins, and the ground is switched, modulating the speed.
    Programming wise:
    Software PWM:
    <iochannel id="Digital Output 0" port="15" brain="my fusion brain 0" type="digital_output">
    <defaults defaultstate="off"></defaults>
    <options mode="standard">
    <pulse duty_cycle="50" period="XX"></pulse>
    </options>
    </iochannel>
    Hardware PWM:
    <options mode="pwm">
    </options>
    </iochannel>
    1.9in x 2.9in -- 47mm x 73mm
  6. #26
    Jul 2007
    any update on the HVAC controlls by chance? I've had my fusion brain 6 for almost 2 years now. still have no clue what I'm doing. lol
  1. Taking bugfix requests for 2.3.7
    By phat_bastard in forum Media Engine
    Last Post: 01-14-2008, 11:35 AM
  2. Replies: 10
    Last Post: 09-07-2007, 04:01 PM
  3. Updated Bugs and Requests thread
    By GReeToZ in forum Centrafuse
    Last Post: 03-02-2005, 01:28 AM
  4. D3 Front End: Enhancements/Feature Requests
    By Dominik in forum Map Monkey
    Last Post: 12-28-2004, 02:44 PM
  5. Replies: 15
    Last Post: 03-07-2004, 10:23 AM
