resistor size doesn't really matter, as long as you use one around 100 ohms. you then use the voltage divider formula and resistance to PSI conversion posted above in MDX to get PSI
Hi All
Can i just check my wiring here as im in the middle of setting this up. Does this look right:
And is that the correct size resister for the 150psi Dakota unit?
Thanks in advance
Ken
nick might make a function that does this automatically... would be pretty sweet.
like a curvefitting function
Are you talking about the
airridepressuresensormodule.xml
airridepressuresensormodule.designer
files
As far as i was aware they do the job of taking the input (voltage) and converting it to the Output (Psi).
Is that not correct?
Ken
those will work if Nick posts the resistor he used while building those files
nick confirmed: his code is based on a 100ohm resistor.
Hmm ive got this thing wired up like my diagram above and i am getting a reading of 452, surely on a 150psi unit that's not possible.
edit
This is the airridepressure function:
Ok im going back to basics here.
Forget PSI for the moment, lets just work with voltage, if i open up the standard skin and plug in the sensor on its own with no resistor and no PSI converter i get 4.87 which is the volts obviously
However if i then install the 100ohm resistor, that voltage should still change to a much lower figure surely, well this doesn't change at all which leads me to assume ive got something wired incorrectly.
Is there anyone out there who has actually got a pressure sensor working on this FB board?
Ive got it exactly wired as in my picture above, can anyone shed any light on the subject as ive hit a wall right now.
