Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
Thread: Tutorial - Air Ride Suspension
  1. #51
    Newbie bad_luck's Avatar
    Jun 2009
    Heerlen, Netherlands
    now, i have a setup with simple 2 tanks, 4 airbags, a compressor, the airswitches and a display with 8 buttons on it and 4 digital gauges connected to a computer.
    What i want to do, is put 4 2-way switches in my car, and make the pressure readable in centrafuse. If possible i would like to send signals to the airswitches, but that's not even really that important.
    The normal switches will be so that I can adjust the rideheight even if I've got a problem with my PC, or if it hasn't started up yet (and I just have to move the car a few meters or so).
  2. #52
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    Do the sensors have more than 2 discrete values? If so then how would a digital input work?
    You need to use an analogue input.
    I will be using the dakota digital sensors.
  3. #53
    Oct 2005
    east coast
    are these the only senors that work with the FB? Im wanting to hook up five air sensors for my air ride. One for the tank, and the other four for the bags. I have to use the SEN-03-5 - Universal Pressure Sender with a 1/8" NPT fitting. Range: 0- 400 psi
    Resolution: 2 psi How would I get the values to plug in?
  4. #54
    Oct 2005
    east coast
    for the air ride sensor, would I need relays?
  5. #55
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    sensor = input
    relay = output
    1.9in x 2.9in -- 47mm x 73mm
  6. #56
    Oct 2005
    east coast
    Okay so I hook all the sensors(5) to the analog inputs. The digital outputs of the FB I hook to the relays, then to the valves. would I be able to control the air ride system through the carputer( tell me how much air is in the tank and bags in psi)?would you be able to pushing the button in the program on the monitor to adjust the height of the car (leveling system)?
  7. #57
    Mar 2006
    That's the idea...
  8. #58
    Oct 2005
    east coast
    That's the idea...
    How would I go about doing the code for the configurator? how do you find the values in psi?. for my type of air ride, I have to use Dakota Digital #SEN-03-5 0 - 400 psi, Universal Pressure Sender / 1/8. For my setup I cant use the 0-150psi pressure sender. will this sender still work? The code on the first page, will that work for the 0-400psi pressure sender unit?
  9. #59
    Jun 2009
    Hi,
    I guess you need some kind of device to hook everything up to a computer...
    How, and where, can I get something like that? Or is there a scheme or something like that to make it myself ?
    And, next step, can I get "standard" software that I can use in centrafuse ?? I have no idea where to start, please help....
    grtz. Bart
  10. #60
    Oct 2005
    east coast
    Quote Originally Posted by bad_luck View Post
    Hi,
    grtz. Bart
    just use the FB to hook to your computer to monitor and control the air suspension. Im not sure about centrafuse, I've never used the software. FB has it own software that you program and make what ever buttons you like it to do. I use streetdeck 2 for my frontend.
  1. What do I need to hook up the air ride suspension?
    By Maheriano in forum Fusion Brain
    Last Post: 12-29-2007, 11:56 PM
  2. DIY: Built a heater for my LCD
    By nobb in forum LCD/Display
    Last Post: 10-27-2007, 02:12 AM
  3. 2003 Civic CarPC (AIR RIDE)
    By kumanan in forum Show off your project
    Last Post: 03-15-2007, 11:20 PM
  4. Air ride suspension
    By keen70 in forum Off Topic
    Last Post: 02-14-2006, 05:05 PM
  5. Air ride suspension control?
    By dragvette in forum Newbie
    Last Post: 01-22-2006, 04:15 PM
