Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 77
Thread: Tutorial - Air Ride Suspension
  1. #61
    Newbie bad_luck's Avatar
    Jun 2009
    Heerlen, Netherlands
    I might sound stupid now, but what is "the FB" ??
  2. #62
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    the fusion brain, the hardware that lets you control the air ride.
  3. #63
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    How would I go about doing the code for the configurator? how do you find the values in psi?. for my type of air ride, I have to use Dakota Digital #SEN-03-5 0 - 400 psi, Universal Pressure Sender / 1/8. For my setup I cant use the 0-150psi pressure sender. will this sender still work? The code on the first page, will that work for the 0-400psi pressure sender unit?
    The code is for the 150psi unit. If you use something else than you will need to calibrate it, or find a pre-done curve. If you find a predone curve, then you can plug it into Excel and get an equation easily.
    1.9in x 2.9in -- 47mm x 73mm
  4. #64
    Jun 2009
    and where can i get this fusion brain ?
  5. #65
    Mar 2006
    Quote Originally Posted by bad_luck View Post
    Both at our store (in my sig) and in the mp3car store (top banner).
  6. #66
    Oct 2005
    Quote Originally Posted by 2k1Toaster View Post
    how do I calibrate it? is there a pre-done curve? how did you get the code for the 150psi one?
  7. #67
    Oct 2005
    anyone have info on this?
  8. #68
    Mar 2006
    You calibrate it by reading in values and comparing it to known values. So put the system at X psi, read in the value, and therefore that value = that psi. Change system to psi Y, then read in the value, and therefore that value = Y psi.
    You have to look at the sensor datasheet to see if they already have a curve. More than likely one exists somewhere, probably in psi vs. resistance.
    We got the code for the 150psi by doing exactly as I described above.
  9. #69
    Nov 2004
    St Louis
    Good luck with that. Here's what I got.
    This is what the engineers at Dakota Digital were able to find for me:
    Resistance PSI
    20 16
    75 114
    100 164
    150 280
    Someone probably needs to call them again and see if they ever found more data.
  10. #70
    Oct 2005
    Quote Originally Posted by GizmoQ View Post
    Resistance PSI
    20 16
    75 114
    100 164
    150 280
    I see most people with gauges in their cars(Chrysler 300) run like 90-98 psi int the front 100-106 psi in the rear with the 400psi sensors. I only can use this sensor, so are the numbers above all psi or resistance?
  1. What do I need to hook up the air ride suspension?
    By Maheriano in forum Fusion Brain
    Last Post: 12-29-2007, 11:56 PM
  2. DIY: Built a heater for my LCD
    By nobb in forum LCD/Display
    Last Post: 10-27-2007, 02:12 AM
  3. 2003 Civic CarPC (AIR RIDE)
    By kumanan in forum Show off your project
    Last Post: 03-15-2007, 11:20 PM
  4. Air ride suspension
    By keen70 in forum Off Topic
    Last Post: 02-14-2006, 05:05 PM
  5. Air ride suspension control?
    By dragvette in forum Newbie
    Last Post: 01-22-2006, 04:15 PM
