Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: Tutorial - Air Ride Suspension
    Fusion Brain Creator
    Mar 2005
    Hardware
    So far, the only sensors we have data for are the Dakota Digital sensors.
    http://www.dakotadigital.com/index.c...rod/prd124.htm
    Code:
    150psi, 1/8-27 NPT
    PSI		R typical	R max		R min
    0		10		13		5
    14.5		31		35		27
    29		52		56		48
    43.5		70		74		66
    58		88		92		84
    72.5		106		111		101
    87		124		129		119
    101.5		140		150		130
    116		155		170		145
    130.5		170		185		155
    145		184		214		154
    Maximum 435 psi for 2 seconds only.
    Operating Temperature:  -13F - +212F (to +248F max. 1 hour) on
    connecting thread.
    Then, all you need to do is hook the air ride sensor up like so, knowing that the body of the sensor is grounded.
    As far as software, Nick will be along shortly to do that bit.
    Mar 2006
    Colorado, but Canadian!
    To Evaluate an Analogue Input as an Air Ride Sensor
    Configurator Designer File: http://www.fusioncontrolcentre.com/T...odule.designer
    Function XML File: http://www.fusioncontrolcentre.com/T...nsormodule.xml
    Put both into your Configurator's function directory.
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <function>
      <input order="1">PressureInput</input>
      <return type="numeric">
      <operation type="subtract">
        <parameter1>
          <operation type="add">
            <parameter1>
                <parameter1>
                  <operation type="multiply">
                    <parameter1>
                      <number>8.4879</number>
                    </parameter1>
                    <parameter2>
                        <parameter1>
                            <parameter1>
                              <variable do="get">PressureInput</variable>
                            </parameter1>
                            <parameter2>
                            </parameter2>
                          </operation>
                        </parameter1>
                        <parameter2>
                        </parameter2>
                      </operation>
                    </parameter2>
                  </operation>
                </parameter1>
                <parameter2>
                    <parameter1>
                      <number>27.568</number>
                    </parameter1>
                    <parameter2>
                        <parameter1>
                        </parameter1>
                        <parameter2>
                        </parameter2>
                      </operation>
                    </parameter2>
                  </operation>
                </parameter2>
              </operation>
            </parameter1>
            <parameter2>
                <parameter1>
                </parameter1>
                <parameter2>
                  <number>49.943</number>
                </parameter2>
              </operation>
            </parameter2>
          </operation>
        </parameter1>
        <parameter2>
          <number>18.313</number>
        </parameter2>
      </operation>
      </return>
    </function>
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    To Use above code
    Insert this into your logic area (between "<logic>...</logic>". You obviously need to replace the analogue id with the id you declare in the io section "<io>...</io>". And you must reference the above code in a seperate function file in the "<require></require>" area.
    **Note: The "..." in the following code mean that there can/will be other non-related items between the code sections. Fusion Control Centre Uber Edition doesn't care about the order. It only cares about heirarchy. Meaning "<iochannel>...</iochannel>" must occur between the opening "<io>" and closing "</io>" tags. If it is not in there, FCC will skip right over it, and that input channel will never be created.
    Code:
    <require>
        <!-- Begin Function Instances -->
        <function file="content\config\AirRidePressureSensorModule" id="AirPressureSensor"></function>
        <!-- End Function Instances -->
    </require>
    <io>
      <!-- Begin Analogue Input Instances -->
          <iochannel id="RF Air" port="0" brain="TucciBrain2" type="analogue_input">
            <options history="10" auto_average="true"></options>
          </iochannel>
          <iochannel id="LR Air" port="1" brain="TucciBrain2" type="analogue_input">
          </iochannel>
          <iochannel id="LF Air" port="2" brain="TucciBrain2" type="analogue_input">
          </iochannel>
          <iochannel id="RR Air" port="3" brain="TucciBrain2" type="analogue_input">
          </iochannel>
      <!-- End Analogue Input Instances -->
      </io>
    <logic>
      <!-- Begin Variable Declarations -->
        <all_variables>
          <variable name="Variable_LeftFrontAir">50.0</variable>
          <variable name="Variable_LeftRearAir">50.0</variable>
          <variable name="Variable_RightFrontAir">50.0</variable>
          <variable name="Variable_RightRearAir">50.0</variable>
        </all_variables>
      <!-- End Variable Declarations -->
        <all_statements>
          <if fire_on="logic">
            <parameter1>
              <variable do="set" name="Variable_LeftFrontAir">
                <evaluate function="AirPressureSensor">
                  <input order="1">
                    <analogue id="LF Air" time="0"></analogue>
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
              <variable do="set" name="Variable_LeftRearAir">
                  <input order="1">
                    <analogue id="LR Air" time="0"></analogue>
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
              <variable do="set" name="Variable_RightFrontAir">
                  <input order="1">
                    <analogue id="RF Air" time="0"></analogue>
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
              <variable do="set" name="Variable_RightRearAir">
                  <input order="1">
                    <analogue id="RR Air" time="0"></analogue>
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
        </allstatements>
    </logic>
    Philly
    2k1toaster,
    In what program does this have to be written in?
    and
    I see that this is an XML, Will I need to open this in a webpage? can I incorporate it to Streetdeck some how?
    Where is the <io></IO> section?
    Mar 2006
    Quote Originally Posted by dasaint80 View Post
    2k1toaster,
    and
    You can write this is any program that supports either xml (Dreamweaver, Word, Free XML Editors scattered around google), or in any plain text editor (Notepad and free ones too, just save the file as *.xml not *.txt).
    You do not need or have to open it in a web browser. You can if you want to view the xml if you have no editor (which if you run windows you do, Start-->Programs-->Accessories-->NotePad).
    This code is only understandable by Fusion Control Centre Uber Edition (FCC). Currently, the latest release of Uber is MDX (Managed DirectX) and downloadable as shown here: http://www.mp3car.com/vbulletin/docu...rsion-mdx.html
    To incorporate into StreetDeck, currently you must embed FCC into Streetdeck as an external program. I have been working on a COM object (I promise I have been, but it is slow going now because of how Vista changed COM objects) which will allow the Fusion Brain to be controlled via a plugin (DigitalMod I believe is the SD term). This COM functionality is not available yet, but I hope it will be before summer. Until then, embedding the program works well. You may have to run SD in "testmode" to enable usage while moving.
    Philly
    Code:
      <require>
        <!-- Begin Font Instances -->
          <font name="LED50" originalSize="50" font_config="Content\config\fonts\FusionFontLED.xml"></font>
        <!-- End Font Instances -->
      </require>
      <graphics>
        <!-- Begin Global Graphic Settings -->
        <main_display designed_for_size="800,620" show_at_size="800,480" menubar="fixed" RunInSystemTray="False" MinimizeToSystemTray="False"></main_display>
        <background_image style="stretch" imagefilepath="Content\Images\Background_Air.png" page="0"></background_image>
        <!-- End Global Graphic Settings -->
        <button id="Left Front Fill" enabled="yes" function="trigger output" functionTargetID="Left Front Fill" vote="absolute" vote_opinion="on" vote_priority="low">
          <images imagePrimary="Content\Images\ButtonUp.png" imageSecondary="Content\Images\ButtonUp.png" imageDisabled="Content\Images\ButtonUp.png" imagePushed="Content\Images\ButtonUp.png"></images>
          <display size="56,56" location="100,212" page="0" z_order="0.0"></display>
          <options imageScaling="stretch"></options>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Left Front Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Left Front Dump" enabled="yes" function="trigger output" functionTargetID="Left Front Dump" vote="absolute" vote_opinion="on" vote_priority="low">
          <images imagePrimary="Content\Images\ButtonDown.png" imageSecondary="Content\Images\ButtonDown.png" imageDisabled="Content\Images\ButtonDown.png" imagePushed="Content\Images\ButtonDown.png"></images>
          <display size="56,56" location="242,212" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Left Front Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Left Rear Fill" enabled="yes" function="trigger output" functionTargetID="Left Rear Fill" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="100,412" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Left Rear Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Left Rear Dump" enabled="yes" function="trigger output" functionTargetID="Left Rear Dump" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="242,412" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Left Rear Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Right Front Fill" enabled="yes" function="trigger output" functionTargetID="Right Front Fill" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="500,212" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Right Front Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Right Front Dump" enabled="yes" function="trigger output" functionTargetID="Right Front Dump" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="642,212" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Right Front Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Right Rear Fill" enabled="yes" function="trigger output" functionTargetID="Right Rear Fill" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="500,412" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Right Rear Fill" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
        <button id="Right Rear Dump" enabled="yes" function="trigger output" functionTargetID="Right Rear Dump" vote="absolute" vote_opinion="on" vote_priority="low">
          <display size="56,56" location="642,412" page="0" z_order="0.0"></display>
          <up_click up_click_function="trigger output" up_click_functionTargetID="Right Rear Dump" up_click_vote_opinion="off" up_click_vote="absolute" up_click_vote_priority="medium"></up_click>
        </button>
       <text_label id="Left Front Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_LeftFrontAir">
          <font font_id="LED50" font_size="35"></font>
          <display location="165,165" page="0"></display>
          <config decimals="0" max_size="70,40"></config>
        </text_label>
        <text_label id="Left Rear Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_LeftRearAir">
          <display location="165,365" page="0"></display>
        </text_label>
        <text_label id="Right Front Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_RightFrontAir">
          <display location="565,165" page="0"></display>
        </text_label>
        <text_label id="Right Rear Air TextIndicator" text="00" auto_monitor="variable" auto_monitorTarget="Variable_RightRearAir">
          <display location="565,365" page="0"></display>
        </text_label>
    </graphics>
      <io>
      <!-- Begin Fusion Brain Instances -->
          <brain id="micerebro">USB\VID_04D8&amp;PID_000C\6&amp;17EF8D69&amp;0&amp;4</brain>
      <!-- End Fusion Brain Instances -->
      <!-- Begin Timer Setup -->
          <timer id="input" interval="100"></timer>
          <timer id="output" interval="100"></timer>
          <timer id="gui" interval="50"></timer>
          <timer id="logic" interval="50"></timer>
      <!-- End Timer Setup -->
      <!-- Begin Digital Output Instances -->
          <iochannel id="Right Front Fill" port="1" brain="micerebro" type="digital_output">
            <defaults defaultstate="off"></defaults>
          </iochannel>
          <iochannel id="Right Rear Fill" port="2" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Left Front Fill" port="7" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Left Rear Fill" port="0" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Right Front Dump" port="8" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Right Rear Dump" port="9" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Left Front Dump" port="10" brain="micerebro" type="digital_output">
          </iochannel>
          <iochannel id="Left Rear Dump" port="11" brain="micerebro" type="digital_output">
          </iochannel>
      <!-- End Digital Output Instances -->
          <iochannel id="RF Air" port="0" brain="micerebro" type="analogue_input">
          </iochannel>
          <iochannel id="LR Air" port="1" brain="micerebro" type="analogue_input">
          </iochannel>
          <iochannel id="LF Air" port="2" brain="micerebro" type="analogue_input">
          </iochannel>
          <iochannel id="RR Air" port="3" brain="micerebro" type="analogue_input">
          </iochannel>
      </io>
      <logic>
      <!-- Begin Logging Setup -->
        <all_logging>
        </all_logging>
      <!-- End Logging Setup -->
        <all_variables>
              </all_variables>
        <all_statements>
            <parameter1>
                  <input order="1">
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
                  <input order="1">
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
                  <input order="1">
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
            <parameter1>
                  <input order="1">
                  </input>
                </evaluate>
              </variable>
            </parameter1>
          </if>
        </all_statements>
      </logic>
    How's this?
    will this monitor and stabilize itself?
    I don't have the car with me to test this. I'll get the car back in about 2 weeks.
    Steve
    Oct 2008
    Quote Originally Posted by 2k1Toaster View Post
    Code:
    <function>
        <parameter1>
        </parameter1>
        <parameter2>
            <parameter1>
                <parameter1>
                    <parameter1>
                    </parameter1>
                    <parameter2>
                        <parameter1>
                            <parameter1>
                            </parameter1>
                            <parameter2>
                            </parameter2>
                          </operation>
                        </parameter1>
                        <parameter2>
                        </parameter2>
                      </operation>
                    </parameter2>
                  </operation>
                </parameter1>
                <parameter2>
                    <parameter1>
                    </parameter1>
                    <parameter2>
                        <parameter1>
                        </parameter1>
                        <parameter2>
                        </parameter2>
                      </operation>
                    </parameter2>
                  </operation>
                </parameter2>
              </operation>
            </parameter1>
            <parameter2>
                <parameter1>
                </parameter1>
                <parameter2>
                </parameter2>
              </operation>
            </parameter2>
          </operation>
        </parameter2>
      </operation>
      </return>
    </function>
    First off i must say that because of this awesome piece of equipment the sky is the limit now. I understand the wiring concept of everything but its the software that is killing me. Ok so i copied this and saved it as an xml. Where do you place the file and how do you reference it in as a separate function file in the MDX configurator.
    <require>
    </require>
    <io>
    </iochannel>
    </iochannel>
    </iochannel>
    </iochannel>
    </io>
    <logic>
    <all_variables>
    </all_variables>
    <all_statements>
    <parameter1>
    <input order="1">
    </input>
    </evaluate>
    </variable>
    </parameter1>
    </if>
    <parameter1>
    <input order="1">
    </input>
    </evaluate>
    </variable>
    </parameter1>
    </if>
    <parameter1>
    <input order="1">
    </input>
    </evaluate>
    </variable>
    </parameter1>
    </if>
    <parameter1>
    <input order="1">
    </input>
    </evaluate>
    </variable>
    </parameter1>
    </if>
    </allstatements>
    </logic>
    Also can someone help me to understand this by giving me a general break down of this. The more detail the better but anything is better than nothing. Thanks
    Mar 2006
    Hi I noticed you PMed me too, so I will just post here so everyone can benefit from it.
    Quote Originally Posted by wrxyboy
    1st- In the function instance of air ride sensor file what do the numbers correspond to and is this function file only good for the 150psi sensors?
    The numbers are how to scale the voltage input to the pressure output. The brain only reads 0-5v, but the pressure is 0-150. By constructing a polynomial function (remember your basic high school math) you can model any function over a given range by using a sum of polynomials with specific coefficients. So a first order is y = mx + b. Second order is y = n*x^2 + m*x + b and so on. That is what the function above does and models the pressure sensor over the given 0-5v input range and 0-150psi output range. Outside of this range ( x < 0 or x > 5) then it all blows up and doesnt work.
    2nd- <variable name="Variable_LeftFrontAir">50.0</variable>
    What does the 50 mean. I got this from your air ride tutorial.
    Any value in the variable declaration, means the default value. When the program starts, that is what it is set to to begin with.
    3rd- I would like to How be able to have a set preset height and go to that preset with just a push of the button. I know to get those preset heights it will have to correspond to the pressure and will raise or lower the car by pressure. How is this written in code? Thanks
    You will need to split it up into when the pressure is above the threshold and another for when it is below the threshold. Then a button will change a variable to 1 from 0 when clicked. A logic block would then turn on an output if above threshold or turn on a different output if below the threshold to raise/lower it and the variable set by the button is 1. Then another block will monitor the pressure and if between 2 values close to around the threshold, it will turn that variable back off to 0. You have to use between or else it would never turn off because 3.14159 does not equal 3.14158 but it is probably close enough, so you want to make a hysteresis.
    Oct 2008
    ok so i know where to add the function instance for the air pressure sending unit, is the logic correct in only getting a reading from the sensor unit and having it display the correct corresponding psi from each sending unit. Thanks
    Mar 2006
    That logic function takes an analogue input "Front Left" and puts the actual value in a variable "Front Left Variable". That is it.
    If you want to do something useful, like make Front Left Variable PSI not voltage, then you need to send the analogue input through the psi function then to th variable.
  1. What do I need to hook up the air ride suspension?
    By Maheriano in forum Fusion Brain
    Last Post: 12-29-2007, 11:56 PM
  2. DIY: Built a heater for my LCD
    By nobb in forum LCD/Display
    Last Post: 10-27-2007, 02:12 AM
  3. 2003 Civic CarPC (AIR RIDE)
    By kumanan in forum Show off your project
    Last Post: 03-15-2007, 11:20 PM
  4. Air ride suspension
    By keen70 in forum Off Topic
    Last Post: 02-14-2006, 05:05 PM
  5. Air ride suspension control?
    By dragvette in forum Newbie
    Last Post: 01-22-2006, 04:15 PM
