Results 11 to 20 of 23
Thread: Documentation - All Sensors
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by partgypsy View Post
    What are the three connections on the relays for? I suppose one is + one is - and the other is ? There is no indication on the male pins. I assume that the power out is very small? So, say I want it to switch on a 110v outlet. What do I need?
    It is a standard relay.
    There is a common, a normally connected, and a normally not-connected.
    Relays have no polarity. The coil sides are wired to the little header pins that plug into the FB.
    You can switch 25A with these relays. If you want 110vac AC then just connected to common and either NC or NO depending on how you want it to work.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Jun 2008
    Georgia, USA
    Check out post #4 in this thread for a good visual on using a 120VAC relay:
    LightSequencer Retrofit Demo
    Thanks,
    Dan
  3. #13
    Jan 2009
    nothing is standard
    Geesh... you explain, like a doctor... or worse... an accountant!
    What is the purpose of a "normally not-connected" pin. "Common" is common to what? Where do I get the mating connector for these relays and what are they called? (Perhaps you sell them as well?)
    Quote Originally Posted by 2k1Toaster View Post
  4. #14
    Mar 2006
    Perhaps a general read up on relays will help. Look at this part of wikipedia: http://en.wikipedia.org/wiki/Relay#Pole_and_throw
    Explains NO, NC, and Common. We sell SPDT relays so the picture there should help too.
    The mating connector for the FB is already soldered on. The mating connector for the relay terminals is a generic spade connector. Available at an auto store or even Radioshack.
  5. #15
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    You can likely get a 100 pack at Autozone for the price of 5 at Radioshack, or such was my experience...2 years ago...
    (The Volume Control (Linear Variable Resistor) datasheet doesn't give a pinout, and I seem to have lost my multimeter)
    ((The supplied cable isn't soldered to the resistor, which is fine but still need to know which is power, ground, the analog signal, and if the LED should be tied directly to the +5V (likely not! ) )
    Update: my findings
    Last edited by UniqelyCommon; 06-15-2011 at 10:50 AM. Reason: spade clarification, link to findings
  6. #16
    Dec 2007
    Orlando, FL
    I'm not much of an electrical engineer, but i want to build a speed sensor using a hall effect sensor and the fusion frequency to voltage convertor.
    The problem i have is that just about ever hall effect sensor I have seen has three pins: vcc, ground and output. The freq. to voltage convertor only has two input pins, so I am not sure how to hook up the hall effect sensor.
    Anybody have ideas on how to make this work (other than recommending a reed switch instead of a hall effect sensor)?
    "The most likely way for the world to be destroyed, most experts agree, is by accident. That's where we come in; we're computer professionals. We cause accidents." - Nathaniel Borenstein
  7. #17
    Mar 2006
    Quote Originally Posted by hellthorne View Post
    I have an unreleased board that does small signal AC measurements and counts them. It has its own USB interface via a virtual COM port. It works on tachometer signals, but it should work on small signals that come from the wheel speed sensors. If you are curious, I can send you a bare board or something.
  8. #18
    Dec 2007
    Orlando, FL
    sure. sounds good. should i send contact info via private message?
  9. #19
    Mar 2006
    Send me an email at FusionControlCentre at gmail dot com
  10. #20
    Raw Wave
    Nov 2009
    Hall effect modules (HKZ1-1 etc) are power in (usually automotive +12V else 5V), GND & pulsed output (usually open collector - ie, pulses to GND) hence can be used on any uPC input (FB etc.
    Hal effect sensors (UGN3503 etc) are similar but they lack the output squaring circuitry and are hence a varying signal - eg, an AC signal usually centered around the mid-supply voltage. Hence analog inputs need to be used, else squaring or pulse circuitry added.
    FYI - both are technically DC outputs since they do not go below 0V (GND). Technically the 2nd type is an AC output offset by a DC bias, but it is still "DC" (both mathematically and circuit-wise).
  1. Budget rear-view camera?
    By BAC5point2 in forum Input Devices
    Last Post: 04-10-2008, 12:21 PM
  2. problems with my o2 sensors please help
    By ironikal78 in forum Off Topic
    Last Post: 03-27-2008, 01:14 AM
  3. Backup Sensors?
    By Shredder in forum General Hardware Discussion
    Last Post: 11-09-2007, 12:31 PM
  4. various sensors...
    By abyssdj in forum FB Sensors
    Last Post: 10-30-2007, 06:35 PM
  5. Automotive sensors
    By Stephan in forum General MP3Car Discussion
    Last Post: 09-20-2005, 03:02 AM
