Results 11 to 20 of 30
Thread: Turn on a Light Bulb using Road Runner Fusion Brain and Road Runner Fusion Document
  1. #11
    Jul 2008
    Lee's Summit
    Send me an email with your number and lets see if we can get you up and going...
    hows that... I have some time this evening if you have time. Maybe I can figure out whats going on for you... hows that.
    Sometimes its the little things that get overlooked that by going over them again we can get it going...
    Batmaninls
    www.evorbust.com
  2. #12
    Jan 2006
    here is the zip
    Attached Files Attached Files
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by djurchicprelude View Post
    here is the zip
    i notice you have rrfusion.ini in your skin file. Thats incorrect. That file should exist in the .dll's folder. Also, do you have .net 2.0 installed. It is a requirement. If these things arent the problem then use use the same skin enclosed in rrfusion's zip file and tell me if it displays your vidpid
    Live mp3Car Facebook Chat
  4. #14
    Jan 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    ok i will try to remove the rrfusion.ini, i have .net 3.5 installed. i tried using the skin that came with the rrfusion zip file and when i press connect nothing happens. what is vidpid though? thanks
  5. #15
    Woodbridge, VA
    Blog Entries
    32
    in short the vidpid is your usb devices special indentifier.. its a string of letters and numbers and it should display as a label in RR upon pressing the connect button with the example skin.
  6. #16
    Jan 2006
    ok, it does not display the vidpin in rr when i press connect, but when i trun the "kitty of doom??" in the MDX configurator, it finds the vidpid for the brain??
  7. #17
    Woodbridge, VA
    Blog Entries
    32
    if you're comfortable in the registry .. go to this key
    "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servi ces\WinUSB\Enum"
    there should be a key named "0". In this key is the vidpid RRfusion reads from. Can you confirm the key exists? What OS are you running? Any language settings or anything like that?
  8. #18
    Jan 2006
    Ok, I went into the registry and took some screen shots,
    Without the Fusion Brain plugged in I got this:
    With the Fusion Brain pluuged in I got this:
    So judging by the second screen shot I have the "0" key. That means my computer reads the fusion brain correct?
    I am running Windows XP service pack 2, only english and all basic settings.
  9. #19
    Woodbridge, VA
    Blog Entries
    32
    looks good to me. I'm baffled honestly lol. Go into rr.ini and enter debugmode=true, then start RR, let it get to the main menu and close it. Then post whats in your debug.txt file. Are you POSITIVE you have .net 2.0 installed? i really dont see what else could be causing the problem
  10. #20
    Jun 2008
    Georgia, USA
    As sonic says, make sure that you have .Net 2.0 installed and not just .Net 3.5 as it is not inclusive of 2.0.
    Thanks,
    Dan
  1. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
