Results 1 to 4 of 4
Thread: need help with mdx/using my FB
    Jul 2010
    I'm new to this i have absolutely no experience with this. My friend introduced me to the fusion brain and we're trying to make it work. using mdx i cant even figure out how to make a button. i've been lurking the site for hours reading and reading. can someone help me make a button using mdx just to turn on a relay using my FB. thank you my email is kylekonvick@gmail.com
    Jan 2010
    Quote Originally Posted by kylekonvick View Post
    Use the ninja kitty wizard to create a button that controls an output. Then go look at the logic so you can get an idea of how the graphical editor is used. That the simplest way to start. Eventually it is handy to be able to edit the code directly but if you don't have any idea, you might as well stick with the configurator and use the gui for now.
    Jul 2010
    thanks i'll give it a try!
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by acbusdriver View Post
    +1
    That's a good way to learn.
    Basically you need to make a FB instance. Then a digital output instance. Then you go into the graphics where you can tell a button to turn on that digital output which is tied to that fusion brain.
    1.9in x 2.9in -- 47mm x 73mm
  1. Summarize FB Gauges in RR
    By halestorm in forum Road Runner
    Last Post: 12-17-2009, 11:02 AM
  2. FB to control audio switching?
    By JonnieBlaze in forum Fusion Brain
    Last Post: 06-29-2009, 05:02 AM
  3. Basic Passive Entry System Using FB & eyeR?
    By w00tw00t111 in forum Fusion Brain
    Last Post: 03-15-2009, 02:55 PM
  4. FB in Linux: can somebody help?
    By nousb in forum FB Software
    Last Post: 03-06-2009, 02:39 PM
  5. Problem with FB Relays not working
    By JohnWPB in forum Fusion Brain
    Last Post: 12-03-2008, 04:47 PM
