Results 1 to 2 of 2
Thread: Control fan speed with PWM and dependent on temp
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    I thought I'd start a new topic for this.
    2K1 pointed to this as a solution for using PWM to control fan speed but could someone point me in the right direction to get the fan speed so it changes based on the ambient temperature in my computer case?
    Hardware wise, you can just hook it up directly. Power it off of the pins, and the ground is switched, modulating the speed.
    Programming wise:
    Software PWM:
    <iochannel id="Digital Output 0" port="15" brain="my fusion brain 0" type="digital_output">
    <defaults defaultstate="off"></defaults>
    <options mode="standard">
    <pulse duty_cycle="50" period="XX"></pulse>
    </options>
    </iochannel>
    Hardware PWM:
    <options mode="pwm">
    </options>
    </iochannel>
    Love
    Jul 2008
    Mechanicsburg, PA
    Nevermind... I figured it out. I know that this is just my fan, but is there anyway to quiet the fan at all? It's very loud with a "chopping" like sound.
    ---------- Post added at 04:00 PM ---------- Previous post was at 03:32 PM ----------
    Nevermind, I used a 10uF cap between + and - of the fan... Sorry I keep wasting peoples time
    Love
  1. Speed-based volume control?
    By bdqpdx2000 in forum DigitalMods (Scripts / API)
    Last Post: 03-14-2009, 04:45 PM
  2. Old car/engine, non ODB, how to get RPM/speed/temp/etc into carputer
    By Confused in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-02-2006, 01:05 PM
  3. Replies: 11
    Last Post: 04-12-2004, 05:10 AM
  4. tach/speed/gas/temp input into computer
    By lazynok in forum Input Devices
    Last Post: 08-22-2003, 09:04 PM
  5. CD Rom speed control?
    By rbarr110 in forum General Hardware Discussion
    Last Post: 04-05-2003, 02:14 AM
