Results 11 to 20 of 23
Thread: Analog Output Voltage
  1. #11
    Oct 2006
    Las Vegas
    Ok, that clears things up. Good deal with the 2 digital outputs. There has got to be a better way than using up 10 digital outs to control a fan in 10 speeds...
    Re: Soild state fan motor driver- Like how expensive(ballpark)?
    As far as the amps thing, I wasn't thinking of anything in particular, actually I thought I saw where you specified that, but looking back, I guess not. So how many amps are we looking at?
    It's been a while...
  2. #12
    Oct 2006
    Las Vegas
    Will we be able to also send specific values to the analog modules as well as sequential raise/lower commands. If not I hope we can get that effect in the software, and have the software give the requisite number of raise/lowers. That would be needed for slider type controls.
    And will the modules be able to communicate current value so the software could know "where" it is at? That might be needed to accomplich the above, as well as be useful feedback to the user on the interface.
  3. #13
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by h3rk View Post
    Yes. The module will use an analog input as a form of closed loop feedback.
  4. #14
    Oct 2006
    Las Vegas
    Any new, or final, word on what the output specs on this thing are going to be?
  5. #15
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    I just got really interested in this. I'm working on software that will steer a tractor. The steering system is electric over hydraulic, so I need to be able to control that valve. It seems that the particular valve I will be using has one electrical input of variable voltage to sense what to do. The simple way to connect it would be to just use a potentiometer. At 50% of the system voltage, it is neutral. Either side of 50% causes it to turn the wheels. Min/Max is at 25% and 75% of system voltage. The amperage requirement is extremely low - less than 1 mA.
    So am I just looking for a digital potentiometer?
  6. #16
    Mar 2005
    Yes. Use one that defaults to midrange and uses Up/Down triggers.
    If you need more in-depth application specific information, email us.
  7. #17
    Nov 2007
    I've been watching the fusion brain for a few months now and it looks hughly promising.
    I think a true 4-20mA output (probably not the driving end of the circuit either) is the way to go since it can be converted to a voltage output with a simple shunt resistor if needed.
    Important:
    Toyota, among other auto manufacturers are controlling accessories and options by wire now, more than ever. If you start directly controlling things like blower motors with a motor drive output, the HVAC controls that run through the ECU will wack out and start thowing check engine codes.
    I've been holding off on a car PC until the HVAC can be done. When this is available, I'll pull the HVAC and radio and in thier place I'll put in a 10 inch widescreen standing on end.
    BTW, I work for a MAJOR electrical controls company (yep, probably that one) and think what you guys are doing is awesome! What are you going to do with the money when you get bought out?
  8. #18
    Oct 2006
    Las Vegas
    Ok, can you give me an example of something in a modern vehicle that runs via 4-20 amps?
    I agree, with a shunt, it has the possibility of being more flexible, but I just don't see the market full of inexpensive sensors or actuators that work this way. Besides, for those who don't have the pleasurable experience of working in industrial controls, voltage is way more intuitive, and the real advantage of 4-20 signals, in this environment, aren't all that important, imho.
  9. #19
    Nov 2007
    I cant give you an example, though you probably cant tell me with 100% certainty that there isn't already an example out there in a production vehicle or that there might be an example next year.
    You are right, the flexibility is the best reason - all bases covered...
    For someone needing to add a sensor, the market would be wide open also.
  10. #20
    Jun 2008
    Just a thought
    I am only new to the forum and i am reading the applications of this device with some interest , but i have a specific comment regarding high amperage motor or fan speed control .
    With a digital output of a few bit into a resistor network or an analog output of 0-50k ohms would provide an interface to control of a Pulse width modulator using a simple op amp like a LM324 and a low cost FET with a heatsink you could for under $5 control the speed of a ny Fan upto 30amps or more depending on the FET you use.
    Maybe a question for another thread but can this device be used under linux ?
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. OPUS 150 voltage tolerances
    By Mr.Mp3 in forum Power Supplies
    Last Post: 06-03-2006, 09:42 PM
  3. Aux-in Analog audio... will it output from the SPDIF on mainboard?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-07-2005, 10:57 PM
  4. Need help understanding efficiency and voltage regulation
    By sansoo24 in forum Power Supplies
    Last Post: 04-22-2005, 03:45 AM
  5. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
