heh. i'm just gpoing to tag along with you.
i was wondering the same thing but was just gonna wait until i got it. is it possible for the outputs to act as a momentary switch?
actually i know the answer is yes since i have seen the air ride posts and whatnot. in for explanation.
*edit - just found the answer in a thread i had not seen before. the outputs are configurable to act as momentary switches, meaning power is only output while you are pressing the button. so basically you would just run the output through a relay and connect the 12v to the window motor, 1 for up, 1 for down. not sure how a negative switched setup would work, but they are less common.
LinkBack URL
About LinkBacks
