Yep...
wtf?
how is this taking so long
86 to one side of the digital output
85 to the other
30 to +12v
87a to lilliput power
energize digital output to break power
if it doesnt work, either your brain (ha, ha) or the relay is broken
Yep...
I'm just thinking that since he's stated a few times that the relay's switch isn't opening, that maybe there's more going on, some sort of parallel path.
For instance, I know that my old lilliput had a 12V barrel connector on it, in addition to the other connector, which also had 12V... the barrel connection wasn't necessary. And then if he's interrupting the barrel plug's power with the relay and the lilli is getting power from both sources, it may seem that the relay isn't functioning properly, beacuse of a parallel path.
Just a thought.
Live mp3Car Facebook Chat
try swapping with a known good relay
Make sure the relays you are using are SPDT as 87a is not used on SPST relays per the12volt.com.
SPDT Relay : (Single Pole Double Throw Relay) an electromagnetic switch, consist of a coil (terminals 85 & 86), 1 common terminal (30), 1 normally closed terminal (87a), and one normally open terminal (87).
When the coil of the relay is at rest (not energized), the common terminal (30) and the normally closed terminal (87a) have continuity. When the coil is energized, the common terminal (30) and the normally open terminal (87) have continuity.
The diagram below center shows the relay at rest, with the coil not energized. The diagram below right shows the relay with the coil energized. As you can see the coil is an electromagnet that causes the arm that is always connected to the common (30) to pivot when energized whereby contact is broken from the normally closed terminal (87a) and made with the normally open terminal (87).
SPST Relay : (Single Pole Single Throw Relay) an electromagnetic switch, consist of a coil (terminals 85 & 86), 1 common terminal (30), and one normally open terminal (87). It does not have a normally closed terminal like the SPDT relay, but may be used in place of SPDT relays in all diagrams shown on this site where terminal 87a is not used.
Thanks,
Dan
