Results 1 to 2 of 2
Thread: Output Status When Off
    Mar 2004
    Clearly the FB doesnt function when the pc is off.
    When the pc is shutdown does the FB retain the outputs at shutdown and similarly at startup until the software reloads and any changes are made.
    Or is it that as soon as the software is closed/pc is shutdown that output status is null.
    thanks.
    Mar 2006
    Colorado, but Canadian!
    The outputs turn off when the software closes.
    When the software is re-opened it uses the default state set in the configuration.
    So the program is closed on shutdown and reopened if you have it run at startup, or have it embedded in a software that runs at startup.
    1.9in x 2.9in -- 47mm x 73mm
  1. Replies: 7
    Last Post: 01-03-2009, 02:52 PM
  2. using amp output to input?
    By Xprime4 in forum Car Audio
    Last Post: 12-21-2007, 10:26 AM
  3. M-Audio Fast Track Pro: 2.1 Output Possible?
    By speedycheater in forum General Hardware Discussion
    Last Post: 12-10-2007, 02:07 PM
  4. Aux-in Analog audio... will it output from the SPDIF on mainboard?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-07-2005, 10:57 PM
  5. No lcd output
    By JettaMP3 in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:27 PM
