Results 1 to 7 of 7
Thread: Idea for Automatic Door/Gate Opener
    Newbie rightsidenov's Avatar
    Sep 2008
    Orlando, FL
    So I have this idea, and I'm wondering if a) it sounds easy to do and b) if anyone has done it. But I know it's possible.
    I'd like to have GPS monitor my position, and when I get within a certain distance of the gte to my apartment complex, FB sends a signal to a relay that will trigger my gate opener. This could work for garages too.
    Yes, I realize it's a simple push of a button, but my theory is if it's something that is repeated based on a certain set of rules then a computer should be doing it.
    So what's your thought on this outside-the-box idea?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Sorry, kind of an old post to revive, but this is possible now if you are using Road Runner. Check into BlueZX3's GPS Events plugin. It can trigger any event based on your GPS location, and direction of travel. For instance if you are exiting your community, you don't want to trigger the gate opener to open the gate on the entrance side.
    This is exactly something that I am going to do when I get a new car and computer installed. I already took the gate opener apart, and wired a FB output to it to "push the button" on the gate opener. I also ran another set of leads to a small momentary button that can be pressed manually. Sorta a "manual override" so to speak
    My Fiero Build Thread
    Mar 2006
    Colorado, but Canadian!
    The GPS event from Blue's plugin can be sent to send a command to MDX to pulse the output which should work well for a gate. For a garage door, you would need some feedback to know it is open. Rarely does mine open with 1 push, so it would need mkore than 1 pulse but how many is enough? It would always change, so you would need to have something feed info back.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Calgary, Alberta
    Are you guys actually messing with the wiring on the public gates to your complex?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2005
    Quote Originally Posted by Maheriano View Post
    Why would they need to do that?
    They probably have RF transmitters to get in...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    There is no need to mess with the gate at all. I have a remote similar to this one:
    It took it apart, and attached to leads to the button you press to open the gate. Those leads go to the FB, and when Blue's plugin reports I am close to the gate (based on GPS) the FB will close the circuit, thus "pressing the button".
    I am lucky in the fact that the opener will continue to transmit as long as the button is pushed down. So when I get within 10 yards or so of the gate, the FB will press and hold the button, till I am past the gate, and then release.
    May 2006
    Calgary, Alberta
    Oh, I got it. The door to my parkade has a fob I need to swipe on a pad, that sucks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. unique idea?
    By jojor512 in forum General Hardware Discussion
    Last Post: 03-30-2004, 09:15 AM
  2. tracking idea
    By accord in forum GPS
    Last Post: 08-20-2002, 07:20 PM
  3. psu idea
    By jrbless in forum Power Supplies
    Last Post: 05-23-2002, 06:09 PM
  4. A mighty fine idea...
    By Gutter in forum General MP3Car Discussion
    Last Post: 04-17-2002, 01:09 AM
  5. Plugin idea - suggestions anyone?
    By kevmo in forum Software & Software Development
    Last Post: 10-17-2001, 07:50 PM
