Results 1 to 5 of 5
Thread: head lisght control question
    Jan 2005
    ok I have a simple question I want to use the FB to create a auto on/off for my headlamps however I want to keep the factory switch functional for any evens of PC outages
    Hope this hasn't been covered.
    Thanks,
    yonu
    Mar 2006
    Colorado, but Canadian!
    Wire them in parallel, that way either can turn them on but both have to be off for it to be off.
    So manual override will always work/
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2005
    cool wasn't sure if that was ok with a FB
    Mar 2006
    Once you put a relay on the output port, you can consider it like any other relay and wire it accordingly.
    May 2008
    Cape Town, SOUTH AFRICA
    Headlight Auto-dimmer with FB & Lightsensor
    2K1toaster
    How can I use the light sensor and FB to automatically turn off the bright beam of my headlight when there's a car approaching?
  1. question on sony head units
    By jstrain in forum General MP3Car Discussion
    Last Post: 08-12-2008, 08:48 AM
  2. head unit/equalizer question
    By popsson in forum Car Audio
    Last Post: 04-04-2008, 11:18 PM
  3. Replies: 5
    Last Post: 06-08-2005, 02:52 AM
  4. No Head Unit Bass Control!
    By bjm2020 in forum General Hardware Discussion
    Last Post: 03-26-2004, 02:21 PM
  5. Hacking OEM head unit question, PINOUT provided
    By el bob in forum General Hardware Discussion
    Last Post: 02-18-2004, 10:04 AM
