Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Outputs pulsing for some reason...
  1. #11
    Fusion Brain Creator
    Mar 2005
    have you tried MX270's software?
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by QuickSSilver View Post
    No, there is only one version of MDX open. Still can't figure this one out...
    Maybe start from scratch with a skin with one button?
    Well I cant open your config file because I need a function you made for the battery converter as well as the images.
    Can you please zip up your entire MDX directory, exe and all, and post it here so I can test.
    Also what version is your MDX?
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Aug 2008
    Quote Originally Posted by greenman100 View Post
    No, where do I find this? I've tried searching but can't find it.
  4. #14
    Jun 2004
    VB 2k8 code by MX270a:
    http://www.mp3car.com/vbulletin/fb-s...ion-brain.html
    I've been using it & it works well for v3 or v4 (but not with a v3 & v4 running at the same time - see my thread on .dll instances)
  5. #15
    Aug 2008
    OK, I've found the problem!
    It seems as though if I only have two digital outputs and their on/off buttons defined in my config file the outputs pulse on/off when they should be triggered on.
    When I add all of the other (unused at the moment) digital outputs to the config file and set their default state to "off" the buttons work fine and the outputs stay "triggered". Strange!
  1. Replies: 38
    Last Post: 03-12-2007, 01:41 PM
  2. No VGA Signal, for no reason?
    By jjh221 in forum General Hardware Discussion
    Last Post: 02-10-2005, 09:29 PM
  3. PCI Audio card with balanced outputs ?
    By Maximus in forum Car Audio
    Last Post: 02-08-2005, 08:31 AM
  4. Is it possible to map different sound sources to front & rear outputs?
    By Dominik in forum Software & Software Development
    Last Post: 09-27-2004, 10:20 AM
  5. Replies: 2
    Last Post: 10-10-2003, 03:31 PM
