Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: use fb to turn headlamps on and off
  1. #11
    Apr 2009
    Wow, that's great! How is the iPhone scripting done or is it a webpage through virtual desktop over wi-fi?
    Jeff
  2. #12
    Mar 2009
    illinois
    i went back to my car pc and worked on the config program and i did figure out how to get the output to toggle on and off, how would i log for 1 minute and average that to determine light level is high to turn lights off???
  3. #13
    Nov 2007
    hi,
    well i need HOW TO for the headlights automaiton. is there any around??
  4. #14
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Not ment to be rude, but....
    If you do not know what you are doing, don't do it!
    Tempering with headlights can be fatal, if they all of a sudden should turn them self off while you drive at 140km/t and it gets dark all of a sudden.
    So unless you find a howto for your spesefic car, and FB... don't temper with it.
  5. #15
    Nov 2007
    i can easily play around with the hardware part. but the problem is about the spftware thing. i need "HOW TO" on the software part. rest is easy for me. ( wiring, realy and all that stuff)
  6. #16
    Mar 2006
    Colorado, but Canadian!
    Well if you have a specific question I can answer it.
    I cant post a detailed how to for everything...
    What part of the software do you need help with?
    1.9in x 2.9in -- 47mm x 73mm
  7. #17
    Nov 2007
    yeah please, i need the xml file.so that all i do is the wiring part.
  8. #18
    Mar 2006
    what SECTION of the file do you need help with? What part is giving you troubles?
  9. #19
    Nov 2007
    well, i havent started working on this yet, but will surly call for your help when needed.
    thanks
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-08-2003, 12:07 AM
