Results 11 to 20 of 29
Thread: Relay wiring
  1. #11
    Aug 2007
    Northern VA
    Although the pettiness of my problem can't be confidence inspiring, I really do know how a relay works. Now it's certainly possible I am not connecting to the right connectors, but I don't think so. If you want to look at a reference that is a little more relevant to this problem (given the relay marking I have) please look at this and let me know what you think.
    http://www.kpsec.freeuk.com/components/relay.htm
    The relays I have are triggered by 2 wires soldered to the bottom - hard to screw that up if I do say so myself. I started off triggering this with a FB but have also applied 12v (and ground) to them directly with no better results. These are not shown in my diagrams.
    For the rest of it, the page above matches it pretty well. I have 3 connectors, COM, NO, NC, which I expect to work as described.
    2k1Toaster, do you see any problem with the way I am testing or have these wired up?
    thanks,
    charles
  2. #12
    May 2009
    Trigger pins are electrically insulated from NO, COM, NC. You also need to provide power source to the bulb
    EDIT: what type of relay is it? Any model number?
  3. #13
    Newbie Cerberus's Avatar
    Nov 2003
    Quote Originally Posted by cgalpin View Post
    No probably bad choice of words on my part. By series I meant I introduced the relay into the starting circuit by "cutting" one of the lines.
    Testing with a single relay.
    My circuit is simply this
    12v -- bulb -- ground WORKS!
    12v -- COM -- [ relay ] -- NO -- bulb -- ground BULB NEVER COMES ON
    12v -- COM -- [ relay ] -- NC -- bulb -- ground BULB NEVER GOES OFF
    I have bypassed the FB and still have the same behaviour though when applying 12v to the trigger pins. Totally stumped....
    The only difference I noticed with the FB is I hear a hum when the relay is turned on. With direct 12v I hear a very soft click (but have to put my ear close to it to hear it)
    If you wire it 12v -- com -- no -- bulb -- ground and then power the relay
    coil from the 12v direct (no arduino at all) and the bulb doesn't come on...
    then quite simply the relay is goosed!
    Or it's some mad relay that needs huge voltage across it's coil.....
    C
  4. #14
    Aug 2007
    Northern VA
    Quote Originally Posted by digital79 View Post
    Yes which is why I showed you
    This works fine. All I did was add the relay to the circuit. It still has ground.
    Quote Originally Posted by Cerberus View Post
    C
    Yes this is why I am stumped. This should work! But 4 relays act the same way. I guess I'll try the last 2 to be sure
  5. #15
    Aug 2007
    Northern VA
    It's the ones the FB folks sell.
    Potter & Brumfield
    T9AS5D22-24
  6. #16
    May 2009
    This one needs 24V DC for coil, you are supplying 12V.
  7. #17
    Aug 2007
    Northern VA
    wtf! must be that pesky -24 on the model number!
    Dayum. well, that would explain it. Sure will suck if I ordered the wrong ones
    Thanks man!
    charles
  8. #18
    Aug 2007
    Northern VA
    2k1Toasterer I sent ya'll an email as your site doesn't offer choices so the mistake must be on your end. This is what I bought
    http://www.fusioncontrolcentre.com/F...products_id=31
    thanks,
    charles
  9. #19
    May 2009
    The relay on a pic has a 12V coil, you got different ones, 24V model.
  10. #20
    Aug 2007
    Northern VA
    Yeah I'm kicking myself for not realizing that because I did google it as soon as the first try failed and I should have noticed
  1. FAQ: RELAYS; how they work and how to wire it up...
    By FusionFanatic in forum The FAQ Emporium
    Last Post: 10-11-2009, 10:25 AM
  2. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  3. wiring a relay please help
    By 04scooby in forum Newbie
    Last Post: 01-30-2006, 11:56 PM
  4. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  5. Took the plunge - ordered my relay card
    By BeaverWise in forum General Hardware Discussion
    Last Post: 01-06-2005, 10:15 AM
