Results 1 to 4 of 4
Thread: Fusion Brain "email output" problem
    Sep 2009
    Playing around with my Fusion Brain ver 4, I've used the Fusion Control Center Configurator to compare an input value with a reference. When the input goes above the reference, I have the output configured to send an email. The problem is, it continues to send emails as long as the input is larger than the output. Hence, LOTS of emails pile up. Is there a work around to limit the number of emails sent? Also, is there any way to send a text message instead of an email?
    Jan 2005
    ok I am not sure about the multiple email but as to sending a tet check your cell provider i know for instance if you send an email to yournumber@tmomail.net and are on tmobile us then you will get a test or mms depending on the content
    sorry i couldn't be of more help,
    yonu
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Haven't done fusion brain work in awhile but you should be able to use a flag or a boolean or whatever the equivalent is on the device. You set it to true after the first email is sent and then don't send emails if its true next time around. Just remember to set the flag to false when the voltage drops under the reference.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by justchat_1 View Post
    That would work for a one time message yes.
    Another way is to set the "minimum_delta_vote_time" to a large number. That way the email is only sent every "large number" milliseconds. So set it to something like every hour (3600000ms), and you get one every hour. Or per day or something like that.
    1.9in x 2.9in -- 47mm x 73mm
  1. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 11:05 AM
  2. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  3. Fusion Brain Version 4 ready for Beta Testers!
    By greenman100 in forum Fusion Brain
    Last Post: 11-13-2008, 11:21 PM
  4. Fusion Brain Encloser
    By djurchicprelude in forum Fusion Brain
    Last Post: 10-27-2008, 08:42 AM
  5. using fusion brain to delay turn on of amp
    By theheel in forum Fusion Brain
    Last Post: 08-27-2007, 10:33 PM
