Results 1 to 4 of 4
Thread: Linking input and output
    Aug 2007
    I've searched and read (probably not in the right spot) but I can't figure out how to have an output based on an input. For instance, I want my fans to kick on at a certain temp and then off below that temp.
    I have tried to figure out how to do this but I'm workthless when it comes to this coding stuff and am just confused as all getout. It took me 2 hours just to figure out how to generate the I/O with the kitty wizard and to be able to manually turn things off and on.
    Jay
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    In simplest terms If Temp > 190 Then Fan on, Anti-then Fan off. In practice, this will probably oscillate off and on. Could add a lot of averaging and fudge temperature to a lower setting. Better would be on at one temp, off at a lower temp
    Attached Files Attached Files
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ACCLR8N View Post
    That is exactly correct! You beat me to it again
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    Thanks, I didn't know about the "then do" part of the equation.
    Jay
  1. Speaker level input + RCA output?
    By prod in forum Car Audio
    Last Post: 12-10-2008, 05:32 AM
  2. DC Input AC output using MPI-400
    By sathish17110 in forum Power Supplies
    Last Post: 12-27-2007, 11:43 AM
  3. using amp output to input?
    By Xprime4 in forum Car Audio
    Last Post: 12-21-2007, 10:26 AM
  4. Optical Input To Rca Output Converters!
    By Crazystick in forum Car Audio
    Last Post: 01-06-2006, 04:51 AM
  5. Replies: 3
    Last Post: 10-04-2004, 06:13 PM
