I think the problem is actually simple... the board wasn't made to support enough current to the outputs. The resistance is too high and there is too much of a voltage drop. The drop only increases with more current passing through, more
relays, more drop.
This is actually an issue for me now again. Though this brain is perfectly working, and though 11 volts is enough to push a relay, the voltage drop to under 10 volts the brain causes is an issue.
In all honesty, nearly all of my reliability issues in the car are due to the Fusion Brain. I'm swapping it out for an arduino soon.
