Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Digital Output issues
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by creaseguard View Post
    Is there a "how to" file for Centrafusion I can do some reading? I'm not a programmer and get very confused with all this programming language business so having to write an .xml file from scratch to deal with this is a task for me.
    Jay
    inside the .zip folder there's centrafusion readme.txt
    Live mp3Car Facebook Chat
  2. #12
    Aug 2007
    Took a look at the screenies and .txt file. Looks like a good thing for my setup so I'm gonna give it a go and see if I can get this going.
    If I have issues, is it better to post here or on the Centrafuse thread you have going on over there.
    Jay
  3. #13
    Aug 2007
    I just got to thinking and I don't think it's a USB issue. Reason being is that the FB wouldn't work at all if the USB was not coming back on. The FB works because the temp sensors work and the controls for the individual fan relays work based off the temp sensors. The only thing that's not working are the manual control outputs. If it was a USB issue, the FB wouldn't work at all.
    This seems to be an issue of the manual controlled outputs not toggling on after resuming from hibernation.
    Jay
  4. #14
    Woodbridge, VA
    Blog Entries
    53
    Jay
    Post them in the CF Centrafusion thread just to keep all support in one place. And i should let you know a new version of the plugin is gonna be out either today or tomorrow. I made the skin match "Clean" and fixed a problem with static voltage dividers.
  5. #15
    Aug 2007
    Good. I had the puter hang yesterday and had to reboot to fresh desktop. When I did the hibernation again, the problem with the fan and amps not coming on came back. I need to get this solved. Everything else with hibernation seems to work just fine...except for CF hanging after a few on/off cycles from time to time. But hey, that's a PC, I'm going to expect that sort of behavior.
    Jay
  1. Issues with digital signals and dolby pro logic
    By Will Albers in forum Car Audio
    Last Post: 04-26-2006, 11:46 AM
  2. Digital Output - Amps?
    By nFiniteTuning in forum Car Audio
    Last Post: 12-10-2005, 07:15 PM
