Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 101
Thread: Fusion USB I/O Board - What type of sensors would you like to see?
    Mar 2006
    Colorado, but Canadian!
    Alright people, we have a mission for you! What type of sensors would you like?
    Please voice your opinion on both the current sensors, and what people will mention here, so we can guage how many people want what.
    Here is what we have on the table so far definately:
    Photoelectric Sensor (Light)
    3-axis High resolution Accelerometer
    Temperature Sensor
    50 Amp Current Sensor
    Here are some possibilites that have been brought up:
    Ultrasonic Distance Sensor (Backup Sensor or Object Detection)
    Tilt Sensor
    Magnetic Sensor
    So list what you think of these sensors, or ones you have thought of and as always, we will take your comments into consideration as we have done before and will continue to do.
    Let the flow of ideas commence!!
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2005
    air pressure sensors upto 200psi.
    ideally id love to be able to get these to work with the fusion
    http://www.dakotadigital.com/index.c...rod/prd124.htm
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Just a couple of small points. I'd like current sensitivity down to quite small values, say at least 0.1A, which i guess you wouldn't get on a 200A sensor.
    Also, usonic distance sensor is great, just make sure it's waterproof somehow :-P
    Oct 2004
    NY
    , an acurate inline current sensor would be awsome, for the guys who want to read 200amps a clamp on might be fine, but there not very acurate in the low range, I still don't know what a 200amp sensor would be useful for??
    you could add an ir emitter & reciever to be used as a beam to break type setup maybe
    Quote Originally Posted by Ryann View Post
    that should already be usable with the fusion really, what I think would really be friggin awsome would be wireless tire preasure monitoring, but I'm sure that's no easy task...
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    Quote Originally Posted by turbocad6 View Post
    power your amp is drawing? which if that's the best way, id like to see that sensor as an option
    also how about a compass? i know they're fairly cheap and easy to integrate, i've used one on a robotics project
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    I second the compass idea. Definitely a good one.
    Mar 2005
    Quote Originally Posted by DaveDog View Post
    $295
    are you for real?
    Oct 2004
    NY
    Quote Originally Posted by red_parchel View Post
    the problem with that is an amp doesn't have a continuous steady draw, & will draw relative to what it puts out at the time, the meter will jump all over & the readings will be pretty useless for the most part unless theres some sort of smoothing algorithym made that averages, really I think a voltage reading for the heavy draw of a system is more useful data, althogh I guess peak readings may be at least somewhat useful...
    Mar 2006
    Actually I was incorrect when posting about the 200A, it is actually 50A. Whoops...
  1. Replies: 1
    Last Post: 06-10-2005, 04:09 AM
  2. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. Ebay GPS (USB type) unit for sale £45
    By bertybassett in forum Classified Archive
    Last Post: 06-15-2004, 01:11 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
