Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: 150 PSI Air Pressure Sensor
  1. #11
    Aug 2007
    Thumbs up
    Hi All. Dakota Digital http://www.dakotadigital.com have these units SEN-09-3 which is a local pressure sensor for vacumme and 0-30 PSI pressure, ideal for measuring turbo boost. I have asked and they tell me the signal out is 0 to 5 vdc.
    Perfect for the Fusion Brain, and the pressure is right in the range we want to measure so it is going to be nice and accurate.
  2. #12
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    seems that dakota digital has a lot of nice sensors. i wouldnt mind the tire pressure ones.. i bet they all work off of 5vdc..
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  3. #13
    May 2006
    Calgary, Alberta
    I have a bunch of these with my air ride kit, if you have any graphical representations of how you wired it, please post!
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #14
    Jul 2005
    were we at with this?
  5. #15
    Fusion Brain Creator
    Mar 2005
    The post above gives the range of values the sensor works with.
    You want to make a circuit like this:
    +5vdc-->100ohm resistor--->sensor signal lead and fusion brain input--->sensor--->ground
  6. #16
    Jul 2005
    well seein ive never done this sort of ohm businesscan u give me more detail and ill have a go at making some..? you guys wont be making and selling them?
  7. #17
    Mar 2006
    Colorado, but Canadian!
    "Ohm" is the term of measurement for resistance. A resistor at RadioShack is a few cents. It has 2 leads connected usually to a cylindrical plastic or ceramic housing. Inside that housing is "magic" that wastes electricity and turns it to heat (seriously, well not the magic part. ) So you take +12v from the car into any side of a 100Ohm resistor. Then the other side of that resistor connects to 2 things. 1 "thing" is the Brain's sensor input. The other "thing" is 1 side of the air pressure sensor. Then the other side of the air pressure sensor goes to ground from the car.
    And we were going to discuss if this would be worthwhile to sell, but as you can see, it is very simple.
    1.9in x 2.9in -- 47mm x 73mm
  8. #18
    Jul 2005
    thanks 2k1, so i need i guess 4 of these 100 ohm puppies, not 180 ohm like said in previous posts in this topic?
  9. #19
    Mar 2006
    100 vs. 180 makes very little difference. It is not uncommon for a resistor to be in the kiloohm to megaohm range (1000 to 1000000) so a difference of 80 isnt too big of a deal in a case like this.
  10. #20
    Mar 2005
    100 and 180 don't make much difference here besides the calibration formula
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  2. Computer to control Air Bag solenoids?
    By speedofsound in forum Hardware Development
    Last Post: 06-26-2007, 06:46 PM
  3. Outside air temperature sensor.
    By popi79 in forum General Hardware Discussion
    Last Post: 02-09-2007, 07:35 PM
  4. COOL carputer with AC?
    By eduardovdr in forum General Hardware Discussion
    Last Post: 01-28-2006, 07:54 PM
  5. fans
    By LudeAtude in forum General Hardware Discussion
    Last Post: 04-23-2004, 01:55 PM
