love at first site greenman.. o golly
This is on its way to me:
http://www.dakotadigital.com/index.c...rod/prd124.htm
and I should have it by the end of this week. I will update accordingly.
O.K. I'll bite. How are you going to hook that to your FBrain? Looks like it only has 2 wires and don't FB sensor inputs have 3? I only ask cause I need the same thing for my air horns.
well, I got it today.
You hook it up through a resistor network. We will provide the adapter cable, and you order the sensors directly from dakota digital.
greenman, ur unreal. im excited! im excited im excited
cheap, probably $7-10. I'll tally up what the components cost.
where are we at with this ???
I want to place the order for the brain, 4 temps and a pressure switch ASAP.
I figure if i gotta pay postage may as well be on the lot, rather than do it twice.
Below are the specs on the 150psi pressure sensor:
Code:150psi, 1/8-27 NPT PSI R typical R max R min 0 10 13 5 14.5 31 35 27 29 52 56 48 43.5 70 74 66 58 88 92 84 72.5 106 111 101 87 124 129 119 101.5 140 150 130 116 155 170 145 130.5 170 185 155 145 184 214 154 Maximum 435 psi for 2 seconds only. Operating Temperature: -13F - +212F (to +248F max. 1 hour) on connecting thread.
so, you just need a 180 ohm resistor. Wire it like this:
+5v
sensor
analog input
resistor
Ground
