I have a project I am working on and someone suggested that I come by here to see if you guys can help me sort some things out.
I have a 1967 Kaiser Jeep M35A2... Is a big arse military vehicle which I've been building for the past year or so. I've customized everything from the body, frame, engine, down to sound system, electronics, and... well... there isn't much which is not been hacked into, redesigned and put back together... If your interested there is a blog with the build here... but its a 21 page all day read... http://www.steelsoldiers.com/index.p...01a25b0aa34b02
Any who... I've got a pretty complicated stereo build in it as is... but I am fed up with CD's and really prefer to go the computer route which will shore up a lot and integrate a lot of unfinished work into one ordeal... I have the background for computers so installing a computer system into a vehicle is a no brainier but... If I am going to do it I want to do it ALL... If im gonna have a touch screen I might as well run all of the gauges from it, why do something half way... My hang up comes with the sensors as from what I am reading the technology is still some what in its infancy and this is where I need some help / advice...
The computer would need to get data from the following sources...
24V electrical system
12V electrical system
Oil psi 0-120psi
Engine temp 0-260 F (or C, im not we todd did)
EGT (its a multi fuel diesel, turned up a pyro is a must 0-1400 F)
IMP (boost psi) 0-25 psi
Air pressure (air brake system) 0-200 PSI
Fuel tank 1 (I have to stick w/ the current sender, what to convert this?)
Fuel tank 2 (ditto)
Speed (0 - a whopping 75 mph.. down hill with a breeze!)
tach (0-3000 RPM)
-dont NEED it but will prolly install it...
-fuel flow (0-5 gpm)
-trans temp (0-220)
-transfer case temp (0-220)
-power steering temp (0-220)
On the tach and speed... I have to install a set of sensors as is for my cruse control system, basically their inline pulse counters, magnetic) used in some of the older cars back in the day when cruse control was an option which simply screw into the manual cables form the engine and transfer case.. Im thinking those would also work for the speed and tach on the computer system but other wise im at a bit of a loss here...
If you look at the build on the truck its a huge money pit... But I am usually incredibly careful with how I spend it and want to make sure im going in the right direction when Im dropping my hard earned pennies...
Any thoughts?...
