Results 1 to 10 of 11
Thread: various sensors...
    Newbie abyssdj's Avatar
    Oct 2007
    England
    various sensors...
    hi, new to the forum but i've just joined up because this fusion brain is interesting me... it MIGHT be exactly what i've been looking for.
    what i need to do is take data from numerous sensors and display it on an 8" touchscreen on the dash... simple so far, however the data i need will be boost pressure, water temp, exhaust gas temp, maybe oil temp, maybe propane gas pressure, maybe cylinder head temp sensor and a few current sensors.
    i noticed theres temp sensors on the fusion brain site, but im not sure they'll do what i need, and theres no boost sensors etc. i need something quite hardcore, as its going into a landrover defender that frequently takes some knocks and bangs. hardly a nice smooth ride! also, i may be able to get temp sensors with the correct thread to screw straight on in the place of the original (broken) water temp sensor, for example.
    so anyway i noticed another thread on here that detailed using a 150psi sensor from dakotadigital with the fusion brain. could the other sensors from them be used? ie. 30psi boost sensor, egt sensor, etc, as they look like they may be more suitable for the job, and if so, how? if not, does anyone know of any alternatives?
    also, does anyone have a direct link to download the fusion software as i'd like to have a look at it and the site wont start the download for some reason, and as im only connected on gprs at the moment its kinda slow to mess around with
    thanks
    Fusion Brain Creator
    Mar 2005
    Just about any sensor can be used with the FB, either directly or through a resistor network.
    Oct 2007
    England
    ok nice.. so for example, what would i need to use the dakota boost pressure sensor with fb?
    Oct 2007
    England
    another thing... how does the software work out the temperature/etc from the sensor data?
    for example, i use the boost pressure sensor on dakotadigital, and my boost pressure is 1bar... how would you configure the software to display whatever voltage that is as 1bar, and how can you make sure it is accurate?
    obviously the same would apply for stuff like temp sensors, etc.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by abyssdj View Post
    Another resistor to create a voltage divider. The Brain only reads voltages from 0 to 5 volts. Not resistance. Most of the sensors are resistive. If the sensor outputs 0 to 12v, then a simple voltage divider again (2 resistors this time) will downscale it to 0-5v.
    It works out the temperature through a formula. It parses the formula and evaluates it.
    Here is a direct download link: http://www.fusioncontrolcentre.com/s...-10-07/FCC.zip
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2007
    England
    hi thanks for that when i've got a few £££ spare i'll order one and have a mess around. i figured thats how it would work out what to show on screen but thought id better check.
    how would you work out the formula you need? by that i mean how do you know what the temperature (or boost, etc) should be at a given output without checking it with another gauge? i assume the sensors come with info that tells you what the output would be at a certain temperature?
    for want of a simple example, if the sensor is outputting 3.5v, that may mean that the temperature is 80degrees... do you know if the dakota sensors include the info that would tell you that?
    Mar 2005
    If you email Dakota Digital, they'll tell you that stuff. If you need help converting sensor data to a formula, post with specifics once you've bought everything.
    Oct 2007
    England
    thanks, ill get in touch with them when I get chance.
    how much would shipping be to england?
    Mar 2005
    about $20, the website will calculate it for you.
    Oct 2007
    England
    ok cool thanks for that
  1. Can sensors be added to the computer?
    By alexgray104 in forum Input Devices
    Last Post: 07-05-2007, 11:51 AM
  2. Car Alarm Sensors
    By adaminc in forum Hardware Development
    Last Post: 03-29-2006, 04:17 AM
  3. Automotive sensors
    By Stephan in forum General MP3Car Discussion
    Last Post: 09-20-2005, 04:02 AM
  4. temperature sensors
    By frankz in forum Hardware Development
    Last Post: 06-14-2005, 04:11 AM
  5. Need help finding idle and temp sensors
    By wizardPC in forum Off Topic
    Last Post: 05-07-2002, 12:40 AM
