Results 1 to 8 of 8
Thread: Current Sensor
    Oct 2006
    Las Vegas
    Current Sensor
    Is your current sensor an in-line design? Or is it inductive (do I put the sensed wire under that chip)?
    If it's 'in-line'? what kind of terminals is it set up for, I can't quite tell from the pic how to connect.
    Fusion Brain Creator
    Mar 2005
    inline, solder wires to the PCB. The holes in the PCB are sized to handle about a #14 wire.
    Oct 2006
    Las Vegas
    hmmm, how would one safely approach an install where 30-40Amps was expected (obviously, 14AWG is too small to handle that). Do you think a one inch long lead with a spade would be ok for that situation? Or should I go with a different, expensive inductive sensor?
    May 2007
    I was wondering this as well. I was planning on ordering 2-4 of them in order to measure the current draw of my amp(s) using 2 per amp in parallel in so the limit would be 100A in case it hits over 50A drawn. I'd be using 4ga wiring which obviously wouldn't fit in the hole if it's designed for 14ga?
    Mar 2005
    You can't use two in parallel, that's for sure.
    The sensor can handle 50A, maximum. It's a good idea to keep the sustained current around 25A. 14 gauge wire is fine for that, and 12 gauge might fit in the hole.
    In future revision of the sensor, we will make the hole and traces bigger.
    May 2007
    Okay, my thinking was running the 2 in parallel would split the current in half and then just re-add the values in software.
    ................../-sensor--\
    Wire --------...............------------wire
    ..................\-sensor--/
    Mar 2005
    the trouble is, the current won't split evenly. it'll overload a sensor.
    May 2007
    ah ok. thanks for clearing that up
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 04:01 PM
  3. Replies: 231
    Last Post: 10-26-2007, 05:41 PM
  4. Current draw when PC is off/in hibernation.
    By Arathranar in forum Power Supplies
    Last Post: 01-25-2005, 04:21 PM
  5. Suggestions for current for a USB relay controller...
    By Zac in forum General Hardware Discussion
    Last Post: 05-28-2004, 12:52 AM
