Try flipping the connector around and report back.
Here's another question to bug you guys with.. i received my photosensor today and hooked it up to the brain per instructions (red facing the inside of the board). Using a dummy skin i tested the results. No matter if the sensor is in ambient light or in total darkness all it continues to do is jump between two numbers... 0.796 and 0.801. I checked the skin to make sure its reading from the correct port, i've changed ports, i've tried adding the formula ( ($p$/0.016)|p=VINC[!] ) to the #SETTINGS# section but nothing seems to make a difference. What should i check next?
Live mp3Car Facebook Chat
nope didnt not make a difference.. i unplugged the unit switched the connector but its doing the same thing. Here's my section for the sensor input:
Code:#STARTNEW# #NAME#photo #TYPE#PHOTOELECTRIC #SETTINGS#($p$/0.016)|p=VINC[!] #SUFFIX#uW/cm^2 #PREFIX# #SETTINGS# #DECIMALS#9 #VIDPID#USB\VID_04D8&PID_000C\6&42FFB0A&0&2 #SIZE#105,94 #LOCATION#200,0 #SHOWTEXT#true #TXTCOLOUR#LightGray #PAGE#0 #PORT#0 #BORDERSIZE#0 #PLOTLENGTH#100 #ENDNEW#
that's wild. did you try it on multiple inputs? what's it report in the debug window?
there's a chance the sensor is busted, if thats the case, we'll happily replace it
how do i enable a debug window.. i'm simply using the 2.0 software with a hacked up version of the default skin. just moved it to another port and the number change but still dont reflect it knows a difference between dark and light
it's acting like an open circuit, or you're reading the wrong port.
debug window:
click just under the title bar
hold crtl, shift, alt, and type "DEBUG"
type "open raw debug" in the new window
screenshot the debug window
yeah, it's acting like an open circuit. busted sensor.
you can look for a broken connection somewhere if you want, or we can send a new one. email us your address.
i tested the voltage at the 5v metal pin on the sensor end and its receiving power, there must be something wrong within the small plastic casing. If its ok what i'll do is create a new order for the extensions and stuff i planned on purchasing today, and in the notation reference this thread. That way you guys can just ship the new sensor with the rest of my order.
perfect
