Results 1 to 4 of 4
Thread: Accelerometer and Noise Filtering (Moving Average Example)
    Fusion Brain Creator
    Mar 2005
    Often times, in data collection, the raw data is rather noisy. In the figure below, I have connected all 3 axes of our accelerometer to our board, and set the board to log every 100mS.
    I then moved the accelerometer through a serious of orientations, such that acceleration due to gravity (1 G) was sensed on each of the axes. As you can see, the resulting data was quite noisy.
    However, we can apply a moving average to the data inside the MDX software as follows:
    Code:
          <iochannel id="Port9" port="9" brain="TestBrain1" type="analogue_input">
            <options history="10" auto_average="true"></options>
          </iochannel>
    Note the options history and auto average. Options history specifies how many of the past parameters to hold in memory when performing the averaging calculation. For example, in this case:
    Value _new = (Value1 + Value2 + Value3 + Value4 + Value5 + Value6 + Value7 + Value8 + Value9 + Value10) / 10
    where values 1-10 are the past 10 measured values, respectively.
    Then, the accelerometer is put through a range of motions, as shown below:
    The units are 100mS and G-force.
    Hope this helps! Post any questions.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by greenman100 View Post
    Great post...thanks for the tips!
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    Sorry for so many questions
    "The Fusion Accelerometer is accurate up to +/- 6G's."
    Is that the reading range or the accuracy? I know that the accelerometer the Wii remotes use have a reading range of +/- 3G's with an accuracy of 10%. http://www.wiibrew.org/wiki/Wiimote#Accelerometer
    Mar 2006
    Colorado, but Canadian!
    reading range.
    It is accurate up to +/- 6Gs, and after that it is not.
    1.9in x 2.9in -- 47mm x 73mm
