Results 1 to 4 of 4
Thread: Tilt angle sensor
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Tilt angle sensor
    I purchased a Clinometer to measure the tilt angle of something. Thought I'd post some details for anyone looking for something similar.
    Part number 824-02110002, MSI Sensors, Clinometer, Single Axis, Vertical mount. Price of $137 plus shipping.
    This particular sensor is good to 60 degrees either side of center. It has no moving parts, but does contain a fluid which is what is used to determine angle. Unfortunately, that also causes a "slosh" effect while bouncing, so I did have to add some averaging to get it to move smoothly.
    This sensor is ratiometric, so you give it 5 volts, and it will output 2.5 volts when level. Output voltage goes up or down based on which way it is tilted.
    Mouser Electronics Part
    Data Sheet
    Mar 2006
    Colorado, but Canadian!
    nice
    1.9in x 2.9in -- 47mm x 73mm
    Newbie thwack's Avatar
    Sep 2005
    Adelaide, SA
    Also take a look at www.leveldevelopments.com they have a dual axis inclinometer that runs 5v interface similar to that described above. Would be great for anyone with a 4wd interested in seeing the side slope angle or angle on inclinatio going down or up a hill.
    Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
    Car- 1988 Nissan Patrol 4WD
    Mar 2009
    Hey, I've been looking for something like this for my Xterra. I don't have a nice spot for analog gauges, but I have my LCD in that spot.
    What would you use for software interface and to display the date?
  1. Replies: 9
    Last Post: 09-07-2011, 09:15 AM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  3. Mass Air Flow Sensor
    By h3rk in forum FB Sensors
    Last Post: 12-16-2007, 04:15 PM
  4. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  5. Replies: 10
    Last Post: 03-19-2007, 05:45 PM
