Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Are the Digital Inputs Active?
  1. #11
    Dec 2007
    I have a question then. Can the firmware be re-written to use the digital inputs as analog. I need two more inputs and was planning on using the digitals.
  2. #12
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by RonS View Post
    No, it's a limitation of the board, if I remember correctly. The board can only handle 13 analog inputs, and only on certain pins. I'll check when I get home.
  3. #13
    Dec 2007
    Ok thanks. I am going to get one of the new ones when they come out anyway. For right now I can do without the air fuel.
  4. #14
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    so to use them..
    what size resistor would you suggest if you wanted to use a switch?
    also i guess you will need to have the digital inputs code somewhere else and copy / paste it back into the .xml file each time you open the config and change anything?
    as a thought could you treat them like a plugin or 3rd party item and refere to a 2nd .xml file just for the digital inputs
  5. #15
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    I think you can get away with a very high resistance, as you're just pulling the line to a voltage, and there shouldn't be any load on that line. I'd guess a 100K ohm resistor would be sufficient. I think you want to pull the sensed line to ground with that resistor, then put a switch between the sensed line and +5v. That way the input is normally grounded unless you press the switch, which pulls the input up to 5v.
  6. #16
    Jul 2007
    I tried a 470K resistor and it didn't work.
    Nick told me to try something lower, like 470 ohms.
    I'll get to that tomorrow sometime.
  7. #17
    Oct 2007
    Auckland
    if you get it working can you post up a spoon feed of what you did.
    as info seems to be pretty limited.
    im starting to compile my own dummies getting started guide as i blunder my way thru it bit by bit,
    while there is alot of info about, it seems to assume you have it running and know how to program it to a degree.
    having said that i can see the guys are going flat out making it more first time user friendly, with things like ninja kitty (which i got working yay)
  8. #18
    Oct 2007
    Auckland
    just a pointer to an update on this
    http://www.mp3car.com/vbulletin/docu...ml#post1247202
    thanks guys
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. idea for digital inputs
    By wilgartw in forum Fusion Brain
    Last Post: 03-27-2008, 05:23 PM
