Results 1 to 8 of 8
Thread: Outside Temperature sensor
    Jan 2006
    Can the Thermometer sensor just act as a temperature sensor is mounted outside the car?? And used in RR to display the readings? Thanks
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by djurchicprelude View Post
    Yes and yes... i have a temp sensor that is sitting underneath thes pare tire in my car. I drilled thru the metal and epoxied the sensor and it still gets fairly accurate readings. RR can display the data via RRFusion or MDX's COM link.
    Live mp3Car Facebook Chat
    Jan 2006
    Perfect!
    Jan 2006
    When are these things supposed to be back in stock??
    Mar 2006
    Colorado, but Canadian!
    They are in stock, forgot to update the website.
    I will do that tonight.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2006
    Does it come with the header pin on the wires, or do I have to buy that seperate? If I do, Are the 3pin Female to Bare Wires in stock as well?
    Mar 2006
    Comes with header. Plug-n-play
    Jan 2006
    excelent! ordering right now. thanks
  1. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-16-2012, 01:45 PM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  3. Replies: 4
    Last Post: 03-19-2009, 03:53 AM
  4. Use temperature sensor to trigger RR command
    By deus ex machina in forum Road Runner
    Last Post: 10-23-2008, 06:38 AM
  5. Offset for phidgets / temperature sensor
    By skippy76 in forum Road Runner
    Last Post: 10-10-2005, 06:04 PM
