Results 1 to 8 of 8
Thread: water sensor
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    water sensor
    Hey guys,
    I'm toying around with the idea of having a computer controlled ballast system in my boat. I want this to be fully automatic and therefor would need a way to tell the computer when the tanks are full and to stop pumping. I think that tapping into the overflow would be the easiest way to 'sense' when the tanks are full. Basically.. when they tanks fill up, they'll start evacuating the flowing water out of the overflow port. if i could put something there that could sense the water then it could tell fb to shut down the pumps.
    does anyone know of sensor that would fit my needs?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Fusion Brain Creator
    Mar 2005
    2 contacts and a darlington pair
    ala here:
    http://www.zen22142.zen.co.uk/Circui...waterrelay.htm
    Dec 2004
    Los Angeles Ca
    that is perfect... thanks!
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    just a thought since i have some of these ic's laying around but, could you also use a qprox capacitance switch to sense water?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    i guess but a darlington pair is like 20 cents
    Dec 2004
    Los Angeles Ca
    fair enough
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    yeah, the problem is that you'll encounter some issues with residual moisture being enough to trigger the circuit.
    really you probably want a cheap flowmeter like this, with a LED/phototransistor
    http://cgi.ebay.com/Rate-Meter-Serie...3A1%7C294%3A50
    Dec 2004
    Los Angeles Ca
    i wonder if that would hinder the flow of water though.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-16-2012, 01:45 PM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  3. Mass Air Flow Sensor
    By h3rk in forum FB Sensors
    Last Post: 12-16-2007, 04:15 PM
  4. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  5. FS-PC Water Cooling Gear, Hard drives Misc Stuff
    By belezeebub in forum Classified Archive
    Last Post: 04-12-2006, 05:55 PM
