Results 11 to 20 of 24
Thread: 4 Channel Input Isolator and Voltage Divider
  1. #11
    Jan 2008
    Dartmouth, MA
    How many watts does each resistor dissipate?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Completely dependent on the input voltage.
    P = I*R = V^2/R
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Mar 2006
    And blue resistors? Do you have the 3.3v version?
  4. #14
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by 2k1Toaster View Post
    Maybe! That would make sense, since right now the divider isn't making any sense at all.
    I just looked at the Mp3Car store image. The board is different from what I received.
    What I received looks like the following, with big blue resistors in the circled locations which I'm assuming is not the default configuration. Especially since moving the jumper barely makes any difference and no matter what voltage I feed (between 12 and 14 volts) it shows roughly 4.34 - 4.44 on the 5v output side and I couldn't figure out why the range was so small.
  5. #15
    Mar 2006
    Yup, you have the 3.3v version... Not sure how that happened. Just clip the resistors and that should help.
  6. #16
    Jan 2008
    Dartmouth, MA
    Yeah weird, something must have ended up in the wrong box. It doesn't even look like the Mp3Car store sells the 3.3 version though. Hmmm. Oh well, I'll just clip the resistors.
  7. #17
    Mar 2006
    Quote Originally Posted by PaulF View Post
    We do not sell the 3.3v versions to anyone but a very specific couple of clients who they were special made for. That is why this is somewhat confusing.
  8. #18
    Jan 2008
    Dartmouth, MA
    Okay I clipped the resistors, much better as far as heat goes haha
    Now whats the official equation to get the voltage for 15 volt mode. Testing with a multimeter, I came up with
    volts = sensor * 2.96 + 9.63
    It seems that the accuracy is good to within about +/-.1 volts. Is there a better equation?
  9. #19
    Jan 2008
    Dartmouth, MA
    That accuracy is actually worse than I thought. It's way off for higher voltages like 13.5+
    So I'm going to assume there is a much better equation which probably isn't y=mx+b
  10. #20
    Mar 2006
    y = 3E‐06x4 ‐ 0.0004x3 + 0.0183x2 ‐ 0.1488x + 0.2318
    y = What the FB reads
    x = Input voltage
    This is for the 12v jumper setting
