Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 4 Channel Input Isolator and Voltage Divider
  1. #21
    Mar 2006
    Colorado, but Canadian!
    You can see the range is sort of centred on the jumper settings, and you just move that curve around based on the resistor values. Like the 3.3v versions had the center of the linear portion centred around 3.3v which gave good accuracy around the part of interest.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Jan 2008
    Dartmouth, MA
    Alright, the fbd daemon reads in the 0-5 volt analog input as 0-5 volts.
    I want to be able to see the actual voltage.
    So as I understand it y is what the fusion brain is reading on the analog input and in order to get the actual voltage, I need to solve that equation for x?
    Any chance you've already solved that baby for x, I'm at work so I don't have a graphing calculator handy?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  3. #23
    Mar 2006
    Correct.
    I think it is easier to visualize what is going on with the previous graph. For the equation to use in MDX, you would use this:
  4. #24
    Mar 2006
    y = -9E-06x4 + 0.001x3 - 0.071x2 + 1.595x - 2.042
    y = Input Voltage
    x = What the FB reads in
