Results 1 to 5 of 5
Thread: Pluging in Temperature sensor
    Jan 2006
    Whitch is the proper way to plug the sensor in, the red wire towards the fusion brain or away from the brain? also do the pins start at 1 or 0? I ask because either way i try to connect it it shows me in road runner that its not connected??
    thanks!
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by djurchicprelude View Post
    thanks!
    Red wire goes to "+", black wire on the outside goes to "AIN".
    And for testing use the virtual brain in MDX, and you can see exactly what is going on before starting up the COM.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    And when choosing a port, 0 is port 1. It is all labeled on the board.
    Jan 2006
    Quote Originally Posted by 2k1Toaster View Post
    Ok, forgive me if I dont sound very smart at the moment but i am rediculously confused. I have the fusion brain verson 3. Here is a picture ( I know you know what it looks like this is just to help me out)
    does the red wire go to number 1 or number 2?
    also, how do i get into the virtual brain?
    and lastly how do i tell what pins are what port? Do they go in order starting from top to bottom starting with "0"??
    thanks again
    Mar 2006
    Ok well that info for for the v4 as we havent even produced a version 3 in many many months.
    Here is the V2/V3 manual: http://fusioncontrolcentre.com/Fusio...r%20Manual.pdf
    The input is on the outside.
    I dont remember which is 0, but if you open the virtual brain and plug in the sensor it will show you which. To setup a virtual brain, open the configurator, click debug, make sure it is enabled, then select the virtual brain for the brain id listed.
  1. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-16-2012, 01:45 PM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  3. Replies: 4
    Last Post: 03-19-2009, 03:53 AM
  4. Use temperature sensor to trigger RR command
    By deus ex machina in forum Road Runner
    Last Post: 10-23-2008, 06:38 AM
  5. Offset for phidgets / temperature sensor
    By skippy76 in forum Road Runner
    Last Post: 10-10-2005, 06:04 PM
