Results 1 to 2 of 2
Thread: Odometer
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    Odometer
    I need the FB to pulse an output every tenth of a mile to increment an LCD counter I found. This happens to be every 4976 pulses of my VSS.
    Hardware option: All the frequency divider chips I'm finding are divide by 2, 4, 6 or 8. Anybody have a suggestion to divide by 4976?
    Software option: The time based feature Nick put in MDX goes down to whole seconds. Each second it could check the speed and calculate distance traveled. Is it possible to add these values together in a session? Can an IF statement be used to fire an output every time the value exceeds 0.1?
    Fusion Brain Creator
    Mar 2005
    you can get close with 5 chips:
    8*8*6*2*6 = 4606
  1. Standalone odometer wanted
    By ACCLR8N in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-24-2010, 06:51 PM
  2. Odometer and fuel level with OBD
    By adimaths in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-09-2009, 04:29 AM
  3. odometer?
    By Dj-[NRG] in forum Centrafuse
    Last Post: 08-05-2007, 02:02 PM
  4. ODB-II Odometer
    By kiwiuser in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2007, 04:34 AM
  5. Where is yhe Odometer data stored?
    By paul1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-02-2006, 06:04 PM
