+ Reply to Thread
Results 1 to 10 of 11
Thread: Monitoring Wideband O2...Safe?
    Newbie protodelorean's Avatar
    Jun 2007
    I have a wideband O2 sensor connected to my car's ECM. The output of the wideband is 0-5V (perfect!) Is it safe to tap into that signal line and feed one of the FB's Analog inputs so that I can also display a gauge of the A/F ratio, or can the connection to the FB affect the signal that goes to the ECM?
    Thanks, Steve
    May 2007
    It may skew the readings to the ecu. Almost every wideband I have seen, or used, has a programmable output or a second output for an external gauge.....this can be used to feed the FB.
    Jun 2007
    Quote Originally Posted by tom04841 View Post
    Hmmm. That's what I was afraid of. I'm using the PLX wideband unit. It seems to have a single NB and and single WB output. I just shot PLX a note directly to see what they think.
    Thanks!
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    If the impedance on the FB input is high enough in relation to the impedance the ECU is reading the sensor at, it should not vary the signal enough to many any significant difference. The question is... how do they compare? If you know the impedance of both inputs, you can actually figure out how much of a voltage drop it will cause, as that will essentially turn the circuit into a voltage divider.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by malcom2073 View Post
    Yeah, it'd be good to use a voltage follower here.
    Jun 2007
    Holy crap! I'd never heard of a "voltage follower", but I just looked them up and that's exactly what I need. Any tips on components to put one together, keeping in mind my 0-5V signal range?
    Thanks for your help. I really appreciate it.
    Mar 2005
    Quote Originally Posted by protodelorean View Post
    its just an op amp.
    http://electroniccircuitsforbeginner...r-circuit.html
    Nov 2009
    Apparently those PLXs are good for 20mA so I doubt any buffering is needed.
    What's the FB impedance - a few meg?
    Mar 2005
    its been a while, but I think PIC18F series input impedance is real low, like 3kohm
    Jun 2007
    Quote Originally Posted by greenman100 View Post
    With my math that's 5V/3,000ohms = 1.7mA (if I did that right)
    If the PLX can handle 20mA, should I still be looking to buffer? (be gentle. I'm outside my specialty here.) : )
+ Reply to Thread
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. Monitoring and ICE
    By IrishBoy1986 in forum Newbie
    Last Post: 07-02-2007, 03:05 PM
  3. Safe Mode (M10000 Question)
    By MikeyTampa in forum General Hardware Discussion
    Last Post: 08-17-2005, 10:16 AM
  4. Temp Monitoring?
    By mobileh1 in forum MediaCar
    Last Post: 05-26-2004, 09:47 AM
  5. Replies: 0
    Last Post: 05-18-2004, 08:38 PM
