Results 1 to 4 of 4
Thread: Outside Temperature Sensor
    Apr 2010
    What is the best place to attach the outside temperature sensor, so that it does not get a false reading from the engine temperture or the skin of the car..
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Most manufacturers put them inside the front bumper to one side, so that they are away from the radiator, sheltered from windchill amd unaffected by local head from the headlights.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    somewhere in the fender well/bottom front bumper is best. Make sure to seal it with epoxy to make it water resistant.
    Live mp3Car Facebook Chat
    Sep 2007
    Export, PA
    I have mine ziptied to my car's factory ambient air temp sensor...only time it picks up heat from other than actual air temp is when the AC is on and the car is sitting still... otherwise wind doesn't effect it and it doesn't get heat-soaked from other objects... it's located about 2" off the radiator to the right(looking at radiator) on the driver side, bottom corner...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  2. Replies: 2
    Last Post: 01-13-2010, 10:06 AM
  3. Replies: 4
    Last Post: 03-19-2009, 03:53 AM
  4. Use temperature sensor to trigger RR command
    By deus ex machina in forum Road Runner
    Last Post: 10-23-2008, 06:38 AM
  5. Offset for phidgets / temperature sensor
    By skippy76 in forum Road Runner
    Last Post: 10-10-2005, 06:04 PM
