Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Temp sensor correction
  1. #11
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Wow. I stand down sir obd certainly wouldn't fulfill those needs
  2. #12
    Sep 2007
    Export, PA
    yeah......some can like coolant temp, intake temp, ambient temp, and tach signal, but the rest really......at least not something that i can use...
    the biggest thing is i'm using the values i get back from the sensors to determine what i want the car to do..... I'm going to program in a bypass of the stock computer's rad fan control using the coolant temp sensor, automate my HVAC, create a remote starter using the carpc, and once i'm boosted and reading the map and tip sensors...electronic boost control through the CarPC...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  3. #13
    Nov 2007
    PA
    To me that is a more effective way. You wont deal with the delay and latencies of obd. I'd really be interested in how u do the remote starter.
  4. #14
    Sep 2007
    Export, PA
    Quote Originally Posted by Dougw133 View Post
    Well first off, I built a circuit board with some tiny relays on it. This board is what provides the ignition signal for the M4ATX. It uses IGN, ACC, and all door unlock pulse from the remote keyless entry module. Using just some simple diodes I created a latching relay for the unlock pulse so that even when the signal is gone, the carpc can keep running.
    This is the code for the remote start. In my settings screen, i have an on/off switch w/ indicator for remote start. RSCHECK is the command that checks to see if that variable has been set to true. If it's true, it goes through and starts the car. First it turns on the ignition for 4 seconds to let the fuel system pressurize, then blips the starter for the time specified in the settings (in my case .75s). Unfortunately this is not fool proof yet. Once I have my tach signal working, I will add in a timer that after 2 seconds after the starter pulse tach signal is not above 0, that it will retry starting...right now it'll just assume the car's running and thats it...
    Code:
    "RSOFF","GblTmr_Del;RSRUNTIME||DIGITALOUT$O2P$;RELEASE"
    "STARTEROFF","DIGITALOUT$O1P$;RELEASE"
    "STARTERON","DIGITALOUT$O1P$;HOLD||GblTmr_Add;STARTEROFF;$TIMER4$;STARTEROFF;oneshot||GblTmr_Del;STARTERWAIT||GblTmr_Add;RSRUNTIME;$RSTMRLEN$;RSOFF;oneshot"
    "STARTCAR","DIGITALOUT$O2P$;HOLD||GblTmr_Add;STARTERWAIT;4;STARTERON;oneshot"
    "RSCHECK","EVAL;RSTMRLEN;$TIMER2$*60||BYVAR;REMOTESTART;<<STARTCAR<<"
    I'm sure the RRFusion stuff looks a bit funky and that's because i have a custom setup where in RR i can define what options and what inputs are on what ports on the fusion brain...
    I have 4 pages that look like that...2 for outputs, 2 for inputs...
    Right now i only have 1 brain in the system (and that screenshot was taken on my desktop, not the carpc)...if i can get/help shaun finish up his multi-brain RRFusion, then i'll be able to do everything I want to do.....until then I'm running low on ports, lol. If he cant do it then I'm going to have to convert to just using MDX, which is going to be interesting...
  5. #15
    Nov 2007
    PA
    That is awesome man really. Nice work!
  6. #16
    Nov 2007
    PA
    Quote Originally Posted by 2k1Toaster View Post
    The extensions do throw off the accuracy, but it is the same all the time. Meaning you can adjust the reading based on what it should be and that adjustment should work over all temperatures.
    Also, we have a bunch of extensions and other cables in stock now. But mp3car is handling all the shipping right now. The main person in charge of ordering things I guess is on vacation, but I am sure if you email the store, they will in turn email me asking for some.
    Any way I can order them from you guys some how? Custom order?
  7. #17
    Fusion Brain Creator
    Mar 2005
    email us - fusioncontrolcentre@gmail.com
  1. Extreme Temp Hard Drive Experiences
    By Punky in forum Environmental Considerations in Mobile Computing
    Last Post: 02-18-2010, 06:05 AM
  2. Jetway via C7 2.0 gig heat / temp problem
    By blk99l1162 in forum General Hardware Discussion
    Last Post: 08-23-2008, 12:25 PM
  3. temp controlled startup switch
    By americasfuture2 in forum General Hardware Discussion
    Last Post: 07-28-2008, 11:25 AM
  4. Heat preventing system boot...
    By archaic0 in forum General Hardware Discussion
    Last Post: 06-29-2007, 09:46 AM
  5. Temp displayed constantly?
    By Skipjacks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-30-2004, 03:08 PM
