Results 1 to 7 of 7
Thread: Linear Potentiometer pinouts
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    Anybody have a diagram for this? The data sheet was useless. I was expecting the cable to be connected already.
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Usually, the center pin is the sweeper, and the outer are + and -.
    Raw Wave
    Nov 2009
    x2
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Quick write-up
    Probably could use some more info/diagrams
    need to (re)find the datasheet
    (took mine apart to find out )
    Attached Files Attached Files
    Apr 2009
    Davisburg, MI
    Thanks, that's a big help. Still fuzzy on wiring the LED.
    Nov 2008
    Teh Internets
    Me too
    Resistor Calculator but I don't know the data for the LED...yet
    Raw Wave
    Nov 2009
    You can usually assume LEDs to be 20mA and 2V, though the voltage can often be ignored for 12V etc.
    The LED voltage is significant on 3.3V or 5V, but changing resistor value may not make much difference....
  1. Small linear actuators
    By lostreception in forum Ask Cabe Sipes
    Last Post: 07-29-2010, 07:38 PM
  2. Linear Potentiometer
    By MuddyWaters in forum Newbie
    Last Post: 08-08-2009, 11:56 AM
  3. USB, Firewire and other pinouts ...
    By JPMG in forum General Hardware Discussion
    Last Post: 03-04-2006, 08:50 PM
  4. Who knows something about linear actuators?
    By SuperMatty in forum Off Topic
    Last Post: 05-06-2003, 05:22 PM
  5. LCD pinouts
    By lstrunk in forum LCD/Display
    Last Post: 05-29-2001, 06:08 PM
