Results 1 to 8 of 8
Thread: ** NEW ** Fusion Control Centre's Accelerometer Version 2
    Mar 2006
    Colorado, but Canadian!
    This is the first in a new line of sensors that is supposed to be easier to use, more accurate, and more intuitive.
    This accelerometer has slightly better accuracy than the current accelerometer but has a couple extra things that make it tremendously easier to use. One of the big things is that instead of jumpers to select the gain it is a simple slider switch. And ontop of that, when you slide it to an option a little LED lights up to let you know that setting is registered. The +X and +Y directions are printed on the board to make figuring out what axis it is on much easier. (+Z is directly out of the board). There will be (not tested yet) an auto-calibrate function that will help make each sensor as accurate as possible. After soldering and shipping and being manhandled the pressures may be different than when I calibrate them. By laying it on a relatively flat surface face up and pressing the button, it will auto-calibrate within a few seconds. That simple. Another little extra help is the labeling of the Fusion Brain sensor connections. It labels the positive, ground, and sensor output connector. It also labels which port is X, Y, and Z. This sensor can switch between +/- 6G or +/- 1.5G. If you never expect more than 1.5G, then you will get a better accuracy over that range by leaving it in 1.5G mode. For full scale, leave it in +/- 6G mode.
    Some handy dandy pictures:
    1.9in x 2.9in -- 47mm x 73mm
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Kinda obvious from the screenshot, but this sensor will only work with the v6 correct?
    Live mp3Car Facebook Chat
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    It requires 3.3v power. It might be able to handle 4.5v to 5v, but you will be toasting it. I am working on a little adapter board that will convert the 5v of the FBv3 and FBv4 into 3.3v compatible signals. However, this will reduce accuracy/sensitivity of that channel of the FBv3 or FBv6 since it will still have to work over the 0-5v range, but now the incoming signal is 0-3.3v.
    Having said that though, the FBv3 is way unsupported, and there is enough existing sensor stock to carry forwards for the FBv4.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    what would this be useful for in a car pc set up? measure G forces?
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Mar 2006
    Quote Originally Posted by chris350 View Post
    Measuring G forces is the only useful thing it does
    In a car this is very useful for lots of reasons. The primary reason being if you ever take your car to the track or just like to pretend you do Many new cars are equipped with G-Sensors to show lateral acceleration through the turns (how much grip do you really have before your tires float and the back end flies around?). Acceleration forwards is good for measuring your cars actual acceleration curve (it can actually detect the moment VTEC kicks in) and also for seeing how good your brakes are.
    I used it in one vehicle to measure the braking pedal force versus actual braking. There were 2 braking systems per wheel and then the parking brake and a backup brake. The 2 main systems have a few millisecond gap between them when transitioning that some people can feel. Of course when humans "feel" something it is much worse than it is. So gathering empirical data to show it was milliseconds, not seconds was important.
    Outside of the car there are lots of options too.
    Newbie ExplicytDesigns's Avatar
    Apr 2011
    Milwaukee, WI
    So when would this be available for purchase?
    Mar 2006
    Quote Originally Posted by ExplicytDesigns View Post
    I am hoping in 2 to 3 weeks. My manufacturer has had some delays as usual including the month long Spring Festival. :/
    The same time the relay boards (mega and mini), volume control, itty bitty brain, this, and a few more goodies for testing arrive.
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    I wouldn't mind one of these in my car too . My problem is likely to be making an appropriate display embedded into RideRunner - but I'll give it a go! .
    Vauxhall Astra SXi Car PC installed.
  1. Fusion Brain Version 6 -- Firmware Update Version 2.0A
    By 2k1Toaster in forum Fusion Brain
    Last Post: 09-23-2015, 10:55 AM
  2. Replies: 24
    Last Post: 11-01-2012, 04:35 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 06:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 07:56 PM
  5. Fusion Brain version 4
    By MattFreitag in forum Fusion Brain
    Last Post: 08-01-2010, 05:32 PM
