View Poll Results: Awesome?
Voters
12. You may not vote on this poll
  • Indeed
    11 91.67%
  • Nope
    0 0%
  • Maybe, I'll tell you why below
    0 0%
  • What's going on...
    1 8.33%
Multiple Choice Poll.
Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 91 to 100 of 158
Like Tree1Likes
Thread: ** NEW ** Fusion Control Centre's Fusion Volume Knob!
  1. #91
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    the spot i want to mount the knob is lacking space... do you think if i find a clear glass/plastic rod and attach it to the end with hot glue or something or the other...would that work? i may just need like an inch more length on the knob itself.. hmmm....
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  2. #92
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by chris350 View Post
    They make "shaft couplers". One example can be found in this datasheet: http://www.keyelco.com/pdfs/M60/M60p84.pdf
    Mouser sells most of Keystone's products. It would be more solid than hot glue.
    1.9in x 2.9in -- 47mm x 73mm
  3. #93
    Aug 2007
    Queens, NYC
    Quote Originally Posted by 2k1Toaster View Post
    thanks..what size is the shaft of this control?
    CarPc
    Project "Driver"
    Planning [99.9%]
  4. #94
    Mar 2006
    6mm
  5. #95
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    So...
    When do these go on actual sell? Since I managed to break mine Not sure what happened... I was actually installed in my center console (near a cup holder) when I noticed it had not powered on, I switched USB ports and noted it flickering -- thinking it was a USB hub issue took it out and ran inside to test against my main machine - with no light when plugged in there. Checked the usb connector to the device and watched the usb header fall off ... I'm pretty sure there wasn't a lot of strain on the usb cable that plugged into it - But I could be wrong.
    That said, I would love another one (stands by with CC)
  6. #96
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    6mm
    I think you provided slightly more data then what was asked for. Now that's good customer service.
    Quote Originally Posted by Lincolnman View Post
    Your English is fine, don't apologize. You're doing better than most Americans.
  7. #97
    Mar 2006
    Quote Originally Posted by nasa View Post
    So...
    Hmm... Well that's not good.
    I can send you a replacement no charge, just email me your address again so I know which knob goes where.
  8. #98
    Mar 2006
    Quote Originally Posted by kolton5543 View Post
    I do what I can
  9. #99
    Aug 2006
    PA
    Ok,
    I order some very promising knobs (I hope) -- slow boat from China, however. After much research, I found that this takes a "D Shaft" 6mm size knob and this is what I found:
    http://www.aliexpress.com/product-fm...olesalers.html
    http://www.aliexpress.com/product-fm..._5628473&vd=30
    Let's hope they work!
    (they do look cheezey... but what do you expect at 44 cents a piece)
    So I got my cheezey knobs in today -- but can't see how they look since I broke my Volume Control... However, as a quick look - here's what I noted:
    The Bad:
    1. cheap lightweight plastic - I have some aluminum knobs and you can tell the difference upon inspection
    2. Thier a bit short. to sit all the way to the base (where the "D" stops) it would need to be about 13mm talls. These are about 10 - 11mm tall.
    3. Long trip from China...
    The Good:
    1. No set screw, they fit perfectly on the D shaft
    2. Cool looking tops - see pictures from site, they should illuminate just fine
    3. cheap plastic isn't *too* cheap. In most installs, I don'ts see it being all that easy to notice.
    I'll post pics later. And if anyone is interested in trying them out themselves, send me a message (I have a couple extra...)
  10. #100
    Mar 2012
    So my screen is finally showing up this week hopefully so I've got the carputer running in the car this week. I haven't mounted the knob yet, I'm waiting for the screen to come in before I do that, but I just tried using the knob unmounted, it works great.
    Still unsure how to mount it but functionally it works fine in my twenty minutes of testing so far. Will update once I have it mounted.
    Sent from my HTC One X using Tapatalk 2
  1. Replies: 7
    Last Post: 01-26-2014, 10:24 AM
  2. ** NEW ** Fusion Control Centre's MEGA-Relay Board
    By 2k1Toaster in forum Fusion Brain
    Last Post: 12-20-2011, 06:39 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 06:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 07:56 PM
  5. fusion brain v4 car control
    By hachacker5024 in forum Fusion Brain
    Last Post: 07-15-2009, 12:13 PM
