View Poll Results: Awesome?
Voters
11. You may not vote on this poll
  • Indeed
    10 90.91%
  • Nope
    0 0%
  • Maybe, I'll tell you why below
    0 0%
  • What's going on...
    1 9.09%
Multiple Choice Poll.
Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 119
Thread: ** NEW ** Fusion Control Centre's Fusion Volume Knob!
  1. #101
    Mar 2011
    Ohio
    OK, did I miss it again? I missed the Beta, I don't want to miss the actual release. So I'll ask...
    When will these be available?
    How can we order?
    How much?
    Thanks.
  2. #102
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by jhornbr225 View Post
    How can we order?
    How much?
    Thanks.
    I have the same revision as the betas available. I have been trying to contact mp3car about it, but havent really heard back. Not sure what is going on there. One beta tester found that it was easy to pull the USB port off of the board with a certain cable. I have swung the thing around my head by the cable (a formal test ). So I am looking at what I can do. I am thinking a back plate of some kind.
    They will be $27.50-ish. If you want one just like the betas, you can order one today through me directly. If you want one through the mp3car store it will be ~2 weeks after they get back to me.
    1.9in x 2.9in -- 47mm x 73mm
  3. #103
    Mar 2006
    I've added an acrylic base and top that sandwiches the USB connector. Someone was pulling them off the board! This should fix that.
    They are removable if you do not want them, or if you want to put in longer screws to bolt it into something else.
  4. #104
    Mar 2011
    Ohio
    Got the knob today, hooked it up, the volume worked right away, I had to download the drivers and configuration software from a post a few pages back. Now I'm also able to change color.....Cool.
    Looks very nice. Thanks!
    Now I need a knob....
  5. #105
    Mar 2006
    Cool! Glad it works. Any issues with setup or anything?
  6. #106
    Mar 2011
    Ohio
    No, it was really easy after I got the .rar that was posted a few pages back. The volume part worked right away on my Win7 64Bit install, but it said something about missing drivers. I installed from the .rar, then that went away and I was able to change the color. It was nice that you included the cable.
    Although it might be a little weird mounting it. I can use the 4 holes in the board, but most pots and things that look like pots have a threaded shaft with a nut and washers.
    Now I just need a knob.
  7. #107
    Mar 2006
    Great that it worked exactly as it should!
    Nasa's knob's are really nice looking, the LED glows great.
    This isn't a pot, it is an encoder. It makes pretty precise timing measurements between two encoder disks within the shaft. These outputs are pulsed and I measure the pulse essentially. So mounting by the shaft could introduce errors and and would be bad for the internal mechanics.
  8. #108
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    These are now available on the mp3Car Store: http://store.mp3car.com/Fusion_Contr..._p/com-166.htm
    Have a product you would like to sell on the mp3Car Store? PM me for more information.
    Have a car computer question? Ask me by emailing the store.
  9. #109
    Feb 2013
    Western Massachusetts
    what am I doing wrong
    I got one of these Volume Controls last week.
    I plugged it into a USB port on my desktop.
    The two blue LED's on the board lit up.
    There was no reaction of any kind to my plugging it in by my computer. Usually when you plug in a USB device there is some indication my my desktop, even if it is only a little note that plays.
    I turned and pushed the knob shaft. No volume control settings changed.
    I ran the program that I believe is supposed to change the light color. It didn't do anything (read or write).
    What am I doing wrong here?
    Rick
  10. #110
    Mar 2006
    Quote Originally Posted by Rickk View Post
    Rick
    If you see nothing under the device manager change, then try a different USB cable/port. I know they all work because I program them all individually via USB before I package them. You will see a device pop up in Device manager, actually 2 devices. If it is a 64bit system, the first time on a port may take 20 seconds or so to start functioning, but it will be detected right away.
  1. Replies: 6
    Last Post: 02-17-2012, 09:12 AM
  2. ** NEW ** Fusion Control Centre's MEGA-Relay Board
    By 2k1Toaster in forum Fusion Brain
    Last Post: 12-20-2011, 05:39 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 05:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 06:56 PM
  5. fusion brain v4 car control
    By hachacker5024 in forum Fusion Brain
    Last Post: 07-15-2009, 11:13 AM
