View Poll Results: Awesome?
Voters
12. You may not vote on this poll
  • Indeed
    11 91.67%
  • Nope
    0 0%
  • Maybe, I'll tell you why below
    0 0%
  • What's going on...
    1 8.33%
Multiple Choice Poll.
Page 16 of 16 FirstFirst ... 678910111213141516
Results 151 to 158 of 158
Like Tree1Likes
Thread: ** NEW ** Fusion Control Centre's Fusion Volume Knob!
  1. #151
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Dayanum View Post
    Hi, any chance you could reduce the postage cost to UK? I really need this thing but the postage is 30 dollars which is more than the actual product... I don't mind how long it takes to get here, are you able to help? Thanks
    Unfortunately the postage cost is not something I have control over. What you see on the site, is what I get charged. I don't up-charge for "handling". If it says $10, I have to pay $10. The shippers give people that ship a lot of packages steep discounts. My full-time employer gets about 90% discounts and I can send something international overnight through them for less than I can send a box the slowest method domestically with my own business account just because the volumes are so different.
    I am also answering you in a private email, but just wanted to post something here as well.
    I can send via USPS First Class mail which is the slowest method with no tracking/insurance and it gets handed off to the local government mail service on the other side of the pond. Looking up the price, it comes to $12.75 to ship a small box to the UK via First Class from zip 80919 in the USA.
    That's the absolute best I think anyone will be able to find that doesn't have a super awesome giant corporation account.
    1.9in x 2.9in -- 47mm x 73mm
  2. #152
    Feb 2014
    Is there a trick to getting windows 8.1 driver installed (I know not really a driver and not really needed). Just want to clear the device manager error reporting. I keep getting that it is unsigned and windows refuses let it be installed. Win 8.1 X64 system. TIA.
  3. #153
    Mar 2006
    Quote Originally Posted by gwynethh View Post
    Yes there is.
    You have to restart with driver checking disabled and install. It is only good until the next time you restart, but the driver will remain and work forever.
    1. From windows 8 control panel choose General –> Under “Advanced Startup” –> Restart now.
    Now the system will restart and might take some minutes to show up the boot menu. Wait for It patiently.
    After some time you will be prompted with a menu with following options.
    1. Continue
    2. Troubleshoot
    3. Turn off
    Choose Troubleshoot
    Then the following menu appears.
    Refresh your PC
    Reset your PC
    Advanced Options
    Choose Advanced Options
    System Restore
    System Image Recovery
    Automatic Repair
    Command Prompt
    Windows Startup settings
    Choose Windows Startup Settings, then Click Restart.
    Now the computer will restart and the boot menu appears.
    Choose “Disable Driver signature Enforcement” from the menu.
    Now windows will start and you can do the installation of the driver that is not signed.
  4. #154
    Feb 2014
    Thanx. We will try that soonest.
  5. #155
    Feb 2014
    One more question. Can we bypass the USB socket and wire a USB cable directly to the board? Can 4 of the six feed thru holes on the right side of the board be used? Which 4 of the feed thru holes for standard wires of red white green and black? TIA.
  6. #156
    Feb 2014
    anyone?
  7. #157
    Mar 2006
    Those 6 holes are NOT for USB.
    You can however solder to the USB port bottom if you wanted to. Obviously not my problem if you blow it up! The USB connector is very standard and the pinout can be found online for the +5v, GND, D+, and D- connections.
  8. #158
    Feb 2014
    Thanx. Those will be harder but may be necessary due to out mounting restriction.
  1. Replies: 7
    Last Post: 01-26-2014, 10:24 AM
  2. ** NEW ** Fusion Control Centre's MEGA-Relay Board
    By 2k1Toaster in forum Fusion Brain
    Last Post: 12-20-2011, 06:39 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 06:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 07:56 PM
  5. fusion brain v4 car control
    By hachacker5024 in forum Fusion Brain
    Last Post: 07-15-2009, 12:13 PM
