View Poll Results: Awesome?
Voters
11. You may not vote on this poll
  • Indeed
    10 90.91%
  • Nope
    0 0%
  • Maybe, I'll tell you why below
    0 0%
  • What's going on...
    1 9.09%
Multiple Choice Poll.
Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 119
Thread: ** NEW ** Fusion Control Centre's Fusion Volume Knob!
  1. #41
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    Can't wait to get my hands on one of these.
  2. #42
    Mar 2006
    Colorado, but Canadian!
    Importation success!
    1.9in x 2.9in -- 47mm x 73mm
  3. #43
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    I'm really looking forward to this...
  4. #44
    Mar 2006
    They're here! I found a boo-boo, but it is simple to fix. Should be available soon. Currently I have it working with a bootloader so that it is USB upgradable. The current firmware has no illumination of the knob, but I hope in future version to make that configurable to any colour as well as change some parameters. But just plug it into a windows box, wait a couple seconds, and it works. No drivers needed.
  5. #45
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    are you referring to future software upgrades to make it light up or future hardware versions? this one does have lights ... are you having problems with the code to make it light?
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  6. #46
    Mar 2006
    Quote Originally Posted by chris350 View Post
    Future software. The hardware is all there. I can make it glow, but currently I cannot get it to talk via USB with both the volume control and the setup interface. I can do either or, but Windows is barfing when I combine them.
    So the glow isn't programmable currently. Therefore I have turned it off in the firmware. But all I need to do is get the firmware updated and everything works. It will be exactly the same as the FBv6, where you load the bootloader program, then get it into bootloader mode, flash the new firmware, unplug/replug, and it is new firmware. To get into bootloader mode, you hold the volume knob pushed in as you plug it in.
  7. #47
    Aug 2007
    Queens, NYC
    maybe using window drivers is the problem. maybe its own drivers should be used.... i don't know about this stuff
    CarPc
    Project "Driver"
    Planning [99.9%]
  8. #48
    Mar 2006
    It is a problem in the USB descriptors. I have my driver working with the setup, and the default HID driver works with the volume control itself. However if you screw up 1bit in a few hundred bytes of USB descriptors, the device will not enumerate and show up as a problem device. This is where I am at currently. It is just a matter of finding my probable typo that I haven't been able to yet.
    I've spoken with the MP3Car store, and they will have some of these shortly.
  9. #49
    Sep 2005
    Any updates?
    Sent from my Galaxy Nexus using Tapatalk 2
    Car news and wallpaper site: www.carfeed.net
  10. #50
    Aug 2007
    Queens, NYC
    word yo!!...lol..
    whats the word on this item?
    CarPc
    Project "Driver"
    Planning [99.9%]
  1. Replies: 6
    Last Post: 02-17-2012, 09:12 AM
  2. ** NEW ** Fusion Control Centre's MEGA-Relay Board
    By 2k1Toaster in forum Fusion Brain
    Last Post: 12-20-2011, 05:39 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 05:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 06:56 PM
  5. fusion brain v4 car control
    By hachacker5024 in forum Fusion Brain
    Last Post: 07-15-2009, 11:13 AM
